Potter
'E who dares wins,eh Rodders??!
Lads, recently bagged myself a Twincam Fiat engine and I want to know if its a 1'6 or a 2 l. Any stamping on the block or distinguishing features so I don't have to pull the head?
Cheers
Tom
More cars than sense or money!🙄
rodit
Not entirely sure but there are specific forums which i can't remember for the life of me that will tell you in seconds, find a supercharger off a mirorfuri and smile permenantly ;D
Low and slow
Why can't i tune it?
Try the lads on 131mirafiori.com
what is the number on the block? its on the rear right when looking at it from the front.
Potter
Thanks lads! Prompt as always.
Turbo TIpo got no idea mate as the engine is at my other garage and it's blowing a gale outside!! I'll post it up tomorrow,maybe it'll be of some help.
get the number and i should be able to find out.where is the dizzy located?
Potter
Dizzy is on the passenger side of the engine under the inlet manifold. A number cast into the block slightly behind it says 125A FIAT Any help?
Dizzy is on the passenger side of the engine under the inlet manifold. A number cast into the block slightly behind it says 125A FIAT Any help? I have a 1600cc in the Magnum and the Dizzy is on the passenger side front of the engine, not sure of they do on 2000cc though so, eh, that's useless..........................
ta22gt
Dizzy is on the passenger side of the engine under the inlet manifold. A number cast into the block slightly behind it says 125A FIAT Any help? 125A is the code for a 1608 engine from a 125 Saloon circa 67-72. The 1608 is arguably the best of the bunch, so lucky you....
Agreed. Early 125. Rare now-damn good engine.
Potter
Cheers loads for clearing that up lads. Perfect for what I'm planning for it then.
I got hold of a 2.0L one years ago, it came with twin Dellorto's and a cast manifold. They are eight valve, but huge tuning potential. Great sound and way cheaper than a Lotus twin cam!!
