valman
Nov 19, 2009 14:19:04 GMT
hey guys, could anyone post up a picture of a blueprint of a rover v8? or maybe a diagram which shows the width, mounts etc please.. or any other v8 engine, all help apreciated ive had a google but so far no luck thanks
valman
Nov 19, 2009 16:12:24 GMT
a tasty v8 to tempt you?
fogey
Nov 19, 2009 16:25:35 GMT
v8ian
Nov 19, 2009 16:26:12 GMT
Thats a P5/6 engine with the short water pump, SDis were about 30mm longer, and the later serpentine engine is about 30mm shorter than the P5/6, height will vary depending on what induction you fit, carbs are lower than PI, or the federal injection is lowere than all of them
Last Edit: Nov 19, 2009 16:30:08 GMT by v8ian
valman
Nov 19, 2009 16:43:12 GMT
nice one fogey! thats perfect. now i just need the mount points and dimensions etc ;D
thanks ian, will keep that in mind
sowen
Club RR Member Number: 24
Nov 19, 2009 19:04:19 GMT
I have an almost bare rv8 block in my garage I could take measurements from if you tell me where you want the measurements taken from.
Nov 19, 2009 19:10:19 GMT
A few from me: Rover V8:Though as other have said lots of variables depending on age, injection etc. And as you asked for some others: Lexus 1UZ:Chevrolet LS3:And if you're thinking about a LS transplant this thread has all the sump option available. Like this:
valman
Nov 19, 2009 21:03:29 GMT
thanks for the above pictures celicav8! good job with the sump shots I compeltely forgot about sumps being different shapes etc! sowen, if you could tell me the position of the mounts from the front of the water pump housing (if you have it if not go from the front of the block) would be awesome if you could do that AND here is the cause of all the hassle in the first place:
Last Edit: Nov 19, 2009 21:03:49 GMT by valman
sowen
Nov 19, 2009 22:08:36 GMT
From the front face of the block, the first pair of mount bosses are 5 1/4 inches, and the next mount boss is 9 1/2 inches. The picture below shows the p6 type mount fitted. That engine has a short serpentine timing cover fitted, so from the front of the block to the nose of the water pump is approx 6 inches as in the picture below I had a quick look at my other engine, with full p6 front timing cover fitted, and that was approx 8 inches from the block face to the nose of the water pump. I could be a little off there as the engine is buried at an awkward angle. Hope that helps
valman
Nov 19, 2009 22:22:44 GMT
From the front face of the block, the first pair of mount bosses are 5 1/4 inches, and the next mount boss is 9 1/2 inches. The picture below shows the p6 type mount fitted. That engine has a short serpentine timing cover fitted, so from the front of the block to the nose of the water pump is approx 6 inches as in the picture below I had a quick look at my other engine, with full p6 front timing cover fitted, and that was approx 8 inches from the block face to the nose of the water pump. I could be a little off there as the engine is buried at an awkward angle. Hope that helps excellent! thank you very much
sowen
Nov 19, 2009 22:31:06 GMT
excellent! thank you very much No probs
