luckygti
I need to try harder!
Oct 17, 2009 16:41:43 GMT
Need a new drivers window for the Merc. Locked myself out and managed to get my arm through the gap, finger tips touching the handle and BANG Let me tell you that glass goes everywhere!! Close to Ipswich or Andover preferable but obviously courier will be fine too!! Oh its the greenish heat insulating stuff, so that would be preferable but obviously anything will do to get me back on the road
MrKiev
If it aint broken don't fix it !
Oct 18, 2009 11:23:08 GMT
I'm sorry i don't have one Pete, but i've you find one give me a shout and i might be able to collect for you. Working all over the south, south west and Wales if that hepls ya out.
luckygti
Oct 18, 2009 15:54:34 GMT
Cheers Chris. Think I might have found one, 35 quid delivered. Bit of a PITA but that'll teach me Really must get a spare key cut.
Oct 18, 2009 22:07:17 GMT
Before you go spending your money check it's the right one for you 190E they made two type's for the 190E, they will both fit in the hole as normal but the bottom of the glass is different, you will have to take the nearside door card off to see which one you have ?? hope that helps.
MK2 Cortina Estate
luckygti
Oct 18, 2009 22:09:17 GMT
Thanks Rusty, what should I be looking for? What's the difference?
luckygti
Oct 21, 2009 13:24:13 GMT
Little bump Cars getting a bit damp now
Sorry for the delay, the bottom edge of the door glass will either be flat or have an arched bottom edge, what year is your car ?
MK2 Cortina Estate
luckygti
It's a 91. Got one coming now so hopefully it's the right one. Mines flat I think, but didn't have the tools i needed to take the remainder of the window out, so I'll take some tools back and find out! Cheers for the info
