ive recently come across some stud conversion kits on the ebay
cgi.ebay.co.uk/wheel-bolt-stud-conversion-golf-polo-ford-fiesta-Mk1-2_W0QQitemZ170389738888QQcategoryZ72257QQcmdZViewItemQQ_trksidZp4340.m263QQ_trkparmsZalgo%3DSIC%26its%3DI%26itu%3DUCI%252BIA%252BUA%252BIEW%252BFICS%252BUFI%26otn%3D11%26ps%3D63
cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=310160638624&ssPageName=STRK:MEWAX:IT
reason I'm interested in them, is that i need to fit variance bolts or nuts in order to fit mini wheels to my car. Now the problem is that i need to use 10mm spacers on the front to clear the brakes, this rules out using std variance bolts as they are too short.
I'm yet to find anyone who can supply longer ones, hence why I'm considering using studs instead, but I'm slightly concerned about having two points, where things screw together (stud to hub, and stud to nut), rather than then one point of contact there would normally be (wheel bolt to hub)
Do you guys have any advice or suggestions.
