Oct 11, 2009 10:10:04 GMT
Just found these photos whilst looking through Flickr, No really and details about them from what the chaps put up. www.flickr.com/photos/25349554@N03/ < you have to copy and paste link due to it not working. Take a seriously hammered series II 88" Land Rover pick up... Build a custom frame to lower it 14 inches and give it a: -356 Porsche super 90 engine -narrowed swing axle trans -narrowed type III rear end -narrowed type I front end Edited for my dumb spelling!
Last Edit: Oct 11, 2009 13:09:26 GMT by trigger
Oct 11, 2009 10:18:25 GMT
How cool is that? Although, Bryn's probably makes more evolutionary sense.
Just your title's full of win!
@pistonbroker on Twitter
will
Oct 11, 2009 10:22:49 GMT
ooooooooooooooffffffffffffffff
Oct 11, 2009 10:34:19 GMT
That's very cool! I really like that, nice find!
Oct 11, 2009 11:08:59 GMT
There were a few small pics in Ultra VW mag a month or two back , one with it sitting slammed on fuchs too
You've been telling me you were a genius since you were seventeen ... in all the time I've known you I still don't know what you mean !
Oct 11, 2009 11:09:46 GMT
yep, very cool. Odd running gear choice though but being a VW and aircooled fan i can see the appeal I probably would have fitted a built type 1 motor though.
Oct 11, 2009 11:14:39 GMT
Dammit, everytime someone else lowers a LR my RR plan gets more normal. Landies are an often ignored choice for these soirt of mods, despite most other 4x4's getting all sorts of treatment. Anyone tip me off as to the whereabouts of a cheap Scimitar GTE chassis?
chevazon
1939 Chevrolet 2 door coupe, `67 `Zon estate, `87 Ragtop Cavalier, 4 x 800 Drifters,(!) 1500 Drifter
Oct 11, 2009 11:41:35 GMT
try Autofive he must have one lying around.
Oct 11, 2009 12:31:25 GMT
I probably would have fitted a built type 1 motor though. Is the 356 not a type 1 motor anyway?
Oct 11, 2009 12:53:40 GMT
I probably would have fitted a built type 1 motor though. Is the 356 not a type 1 motor anyway? No. It's design is based around the type 1 VW, but the changes Porsche made to give it more power make the Porsches their own unique engine, and it's not similar enough for many of the parts to interchange. This makes it rare and expensive!! Also, depending on the particular model of early Porsche, they had all sorts of wild go-faster stuff on them like dry sumps and overhead cams.
Oct 11, 2009 13:17:42 GMT
I done the topic a bit quickly eariler so sorry about lack of detail and bad spelling, edited it now!, Looks pretty amazing though, I've seen the green one that's often on here which is a favorite of mine but this one is from America.
Last Edit: Oct 11, 2009 13:18:24 GMT by trigger
Oct 11, 2009 13:40:01 GMT
I tried searching for more info on it but drew a blank. Looks like a really interesting build!
Foxy
Making pink manly in the north!
Oct 11, 2009 17:14:31 GMT
Last Edit: Oct 11, 2009 17:15:08 GMT by Foxy
I'm the handsome fella with the cheesy white specs or is that the cheesy fella with the handsome white specs?
RetroMat
Column Shifting!
Oct 11, 2009 17:19:54 GMT
excellent! landrover combined with minitruck and aircooled vw stylings
Oct 11, 2009 18:31:57 GMT
Doesn't work quite as well as Bryn's Win Wagon, but how cool would it be to see the two of 'em together?
Oct 11, 2009 21:26:04 GMT
Is the 356 not a type 1 motor anyway? No. It's design is based around the type 1 VW, but the changes Porsche made to give it more power make the Porsches their own unique engine, and it's not similar enough for many of the parts to interchange. This makes it rare and expensive!! Also, depending on the particular model of early Porsche, they had all sorts of wild go-faster stuff on them like dry sumps and overhead cams. The 356 engine in its later form (after about 53) is a totaly different engine to a VW. The Porsche case is 3 peice, the 3rd part being the front timing cover and about the only interchangable part is the distributer, but a VW part uses a Vacum advance unit, the Porsche one doesn't, so even though it will fit , it won't be any good!!It is difficult to get a lot of power from a 356 or 912 engine because the cam is too close to the crank, making stroking impossible, for larger capacity you have to rely on oversized pistons, most racers build 1600cc screamers, with about 160bhp acheivable. The dry sump engines are the 4 Cam Carrera units, and use gear driven overhead cams, very complicated to re-build, usually at a cost of 60k and up!! the 4 cams were fitted to Spyders, Abarth Carrera's, single seaters and 356 Carrera's, as well as a few specials in 1500 and 1600cc's but were continually developed until they became the Carrera 2 litre engine that was fitted to 356 Carrera 2's and the 904 and some other specials... But, the old Landie probably would be better off with a big type 1 VW motor, they are cheaper and you can get a lot more power out of them!!!
Mine
2003 Honda Accord Wagon 1963 Buick Riviera x1 1/2 1964 Cortina Estate 1932 Ford Tudor sedan 1964 Honda C50 Step thru
The Missus
2000 Toyota Bb 1972 Daf 33 1968 Triumph 1300 1946 Chevrolet Fleetmaster
Oct 11, 2009 21:36:05 GMT
Completely off the wall. And therefore awesome. ;D
Oct 11, 2009 21:44:28 GMT
Nothing constructive to say, so................
THAT RAWKS A PHAT ONE!
Tazzy
Jul 23, 2018 20:01:31 GMT
bump, looking for info on this build
miaspa
Found my flashing Pao again.
