Sept 11, 2009 17:33:46 GMT
RIGHT - QUESTION 2. Has anyone ever moved a caravan chassis/axle on the same chassis ? I suspect it will be a fairly simple job of unbolt, move, measure , drill, bolt in. However, other than alligning the axle perfectly, any other issues ?? I need to cut the chassis I have much shorter from the rear, as I do not want to mess with the "A-Frame" side. This needs to be done in order to get the look right, as well as the weightdistribution a bit more forward. Thanks all for your contributions so far. Pic of said chassis, the idea is to cut about 3foot or a meter off the rear, around about the small long hole bewtween the small ones just behind the wheel. OK, here goes. (again) Has anyone built a teardrop trailer, or even a small custom built caravan ? I need tips, things to avoid, and even plans and measurements if you have. Any advice or recommendation appreciated. Cheers.
Last Edit: Sept 17, 2009 7:35:27 GMT by grizz
Sept 11, 2009 18:01:21 GMT
Your car is not 'epic', this thread is not 'epic'....the OCEAN is epic, the UNIVERSE is epic.... please stop misusing this word!! It would appear Hotrods are the new VWs - aint fashion funny! '69 BUICK LESABRE 350
Sept 11, 2009 18:22:43 GMT
Thanks JS !!
Sept 11, 2009 20:35:18 GMT
there is an american forum/website with loads of plans available, I got the link off someone on here a couple of years ago but i've been kicked out, split up and been through 3 computers since then so aint got it to pass on atm, i'll go a-hunting and see if I can find it.
Last Edit: Sept 11, 2009 20:38:07 GMT by guz
Sept 11, 2009 20:37:36 GMT
93fxdl
Enter your message here...
Sept 11, 2009 20:41:51 GMT
Mark
Sept 11, 2009 20:53:21 GMT
My reply got deleted :\
Anyway, have you thought of making a trailer out of a not so healthy Taunus?
Last Edit: Sept 11, 2009 20:53:54 GMT by Mark
Sept 11, 2009 21:03:55 GMT
Hi again Mark,
Dave built a trailer out of about 4 Taunuses, or at least the bits from them.
I like the teardrop idea though, and hope to go look at a caravan chassis for sensible money over the weekend.
I think the first thread I started was deleted by a sensible mod.
Sept 11, 2009 21:18:27 GMT
I know they look cool but they must be the most impractical caravans ever, also looks like it would take off at moderate speeds. Still want one though.
Sept 11, 2009 21:23:38 GMT
I know they look cool but they must be the most impractical caravans ever, also looks like it would take off at moderate speeds. Still want one though. All the right reasons ;D
Sept 11, 2009 21:27:13 GMT
if anyone round my way is thinking of building one i have a spare indespension set up i aint using.
(Nottingham)
Anglia68
Powered By Boredom.
Sept 11, 2009 21:49:59 GMT
Mark
Sept 11, 2009 23:22:31 GMT
I agree, teardrops look fantastic. I imagine they can't be too hard as long as you keep the design nice and simple!
Sept 11, 2009 23:36:58 GMT
Thats basically what i'm building, but i'm using the back half a of a Range rover instead of a teardrop, bit heavy possibly, but working on the theory it'll go anywhere the Rangey towing it will go.
Sept 11, 2009 23:42:56 GMT
that foldaway one is well cool though! nica and boxy...hmm would look good white with orange wheels and some pinstriping lol This will help you as everything is here more pictures (build thread and an awsome nice trailer!): rides.webshots.com/album/557865367bEPjbZ
Last Edit: Sept 11, 2009 23:48:11 GMT by bigkris
Sept 12, 2009 5:39:43 GMT
Right, just read these links, and I believe it is do-able.
Winter project identified, now just need to assemble the bts, use some common sense and build something.
v8ian
Sept 12, 2009 11:15:34 GMT
My mate built one, pollished ally, split rear window divided by a aerofin, austin devon pickup spats over the wheels, took him forever, then sold it before he built the interior as the council were threatening to remove it as an obstruction, despite argueing it was a security device for his garage, as it was parked accross the front of his workshop doors, he lost and it had to go or be scrapped.
Sept 12, 2009 11:16:43 GMT
2001 HONDA CT110 (NOT RCV)
mrj
Sept 12, 2009 11:38:46 GMT
no need to build one, take one of these : ;D Westfalia hearse...
- 1971 VW 1600 TL Fastback - 1978 Passat GLS Variant - 1980 Audi 100 5E - 1981 VW aircooled panel van (sold) - 1983 VW Jetta Mk.I - 1984 VW Polo Coupé - 1984 VW Passat hatchback - 1987 VW Passat Variant - 1987 VW Passat hatchback - 1988 VW T25
Sept 12, 2009 12:26:46 GMT
WOW !!!
OK Juergen, where do I apply for one ?
