Model: Scala
Year: 1990
Mileage: 146 000
Tax: 2010
MOT: Febuary 2010
Current owner: yes
V5 present: yes
Price: £600 or nearest offer
Contact Details: PM through site for contact details
Additional Information:
I've got a H reg mk2 in LA9V (brilliant black) that’s covered around 145K.
Its mot's till Febuary 2010 and just been taxed till January 2010.
It required no work at the last mot and had no advisories.
Good Points;
Complete suspension overhaul when I got it in Febuary 2008, it had new front wishbones and balljoints, polybushed and adjustable coilovers.
It also has goodridge stainless steel brake hoses all around.
Storm tan leather interior.
New front tyres a couple of months ago.
Alpine type E 6x4 speakers all round (much better than the JBL after market ones usually fitted)
Powerflow stainless steel exhaust system (centre pipe and back box)
Uprated wiring loom for the head lights.
Stainless steel fuel pump holder on the underside.
OE electric window motors, wiring loom and switches included but not fitted, in full working order.
The car overheated due to blocked radiator in November 2008, thus a new radiator, water pump and thermostat were fitted. As a precaution to any possible damage the head was removed and skimmed and the head gasket and cambelt replaced at the same time.
I replaced the front engine/gearbox mount with a second hand one along with the rubber seal for the speedo cable which had perished so I replaced that too last week.
Just collected it from the garage today as it had a leak from the passenger side gearbox flange, this is all fixed and filled with fresh oil.
I thought the clutch was going so a new clutch is included in the sale, however, after adjusting the clutch cable and fixing the oil leak it seems fine.
Bad Points;
Passenger door has rotted around the door handle, replacement door included. (Black)
Drivers door is dented and scraped, replacement door included. (Dragon Green)
Bonnet has some small dents, again a replacement bonnet is included. (Purple in colour)
Front drivers wing has been dented, was quoted £50 to get it pulled out.
Rear drivers wing has been dented near the fuel filler cap, again was quoted around £50 to pull it out.
Looking for around £600 for it as I have moved and no longer have the room to keep it, currently stored at my mothers!
front view
rear view
passenger door rot
rear wing dent
front wing dent
Replacement doors, one still wrapped
Replacement bonnet, solid and straight
Passenger seat
rear seat
Drivers Seat
Year: 1990
Mileage: 146 000
Tax: 2010
MOT: Febuary 2010
Current owner: yes
V5 present: yes
Good Points;
Bad Points;
front view
rear view
passenger door rot
rear wing dent
front wing dent
Passenger seat
rear seat
Drivers Seat
