Hi guy's well i am in a dilema and need advice especially if anyone has been through the same?
I purchased a modern daily start of the year, afetr 3 weeks without any hard use the diff let go and took the box casing with it.
Dealer had the car back and had the box rebuilt under the three month waranty, no arguments but took 6 weeks, at least it got done!
Had car back and could hear a noise so took it straight back, it's ok it may be just bedding in ( not likely i work in a body shop) but it's covered, cool ok.
2 Weeks ago starts to get really noisy so take it back, the main shaft bearing (which was supposedly replaced when box was done) has gone and had the casing again.
Just got car back and shift felt horrible (could be burs rubbing off sais dealer) It is now horrid to shift gears, first and reverse are shocking permenantly and all get very hard to select when warm.
I believe this is all related to the first waranty clame so being after 3 months is still covered as the original clame?
Could i argue it in court that i want a full refund as goods are not and have never been up to standard?
Please help as it's making me fed up with cars full stop and i don't know where i stand.
