DutyFreeSaviour
Aug 10, 2009 12:59:22 GMT
Just a quick one (NOT!) - I've bought the Nissan, going over it and need ot know what's expected standard-wise. As it wasn't my build I want to know what'll be checked/gone over/need to be sorted/tip-top. It ain't a road car as it's paperwork has never been done after re-possession a long time ago (found a nice letter). it's got the usual Recaros', harnesses and it all runs/stops fine.... what else needs to be checked - bodywork is shoddy (not dangerous, just scratched to hell and rust bubbling on door panels) so wanted to make sure I don't drag it all the way from Brussels to go home again Tips - thanks
kee
Aug 10, 2009 13:05:46 GMT
mot's are required to gain access to the track. i know that much.
bstardchild
Club RR Member Number: 71
Aug 10, 2009 13:55:31 GMT
mot's are required to gain access to the track. I know that much. If the car is on European Plates (ie not uk registered) might struggle to produce an MOT...... Common sense then applies
bstardchild
Aug 10, 2009 14:03:59 GMT
Common sense then applies Common sense also applies to - Seatbelts (if required by law) fitted working and being used - Helmets worn and fastened correctly - Arms covered - no T-shirts - Windows no more than 1 inch open (so that an arm can't escape from inside the car in the event of a roll I'm not saying any of the above will be required but I would have said they were sensible points that would be advisable to follow
DutyFreeSaviour
Aug 10, 2009 14:14:04 GMT
Well MoT is definitely not an option, so I'll get everything together and see what/who I can bribeconvince......... Long nights ahead then
kee
Aug 10, 2009 14:14:45 GMT
didn't realise it was gtv, just replied
