Jul 25, 2009 17:43:54 GMT
Any help with this would be much appreciated. In process of swapping the the 2.25 diesel in my series 3 for a 2.5 diesel from a 90. having a problem with the left engine mount as its fouling the fuel pump. Any advice how to resolve this can be resolved? Cheers Pete
1969 Commer VC Lanbourn
1985 VW Golf Cabrio 1.6 GL
1992 Fiat Tipo SX TD
Jul 25, 2009 20:08:18 GMT
Seem to remember that one way around this is to the find the timing belt case and cover from the LDV400 that featured the 2.5 Land Rover red block lump - sure the pump is a little higher on that engine and thus not fouling the mount.
2014 - Audi A6 Avant 3.0Tdi Quattro 1958 - Chevrolet Apache Panel Truck 1959 - Plymouth Custom Suburban 1952 - Chevrolet 2dr Hardtop 1985 - Ford Econoline E350 Quadravan 2009 - Ovlov V70 2.5T 1970 - Cortina Mk2 Estate 2007 - Fiat Ducato LWB 120Multijet 2014 - Honda Civic 2.2 CTDi ES
xlr8r
Jul 26, 2009 22:52:56 GMT
it should be a straight swap using the engine mount from the 90 that goes under the fuel pump.
Jul 27, 2009 20:29:17 GMT
Been doing a bit more research on this since original post, apparantly the 2.25 diesel is a J10 engine while the 2.5 is a J12 engine. the J12 does have a lower fuel pump so its unfortunately not a straight swap into a series 3 like mine.
Apparantly there is a J15 version of the J12 with a higher mounted fuel pump used in some 80's sherpa's and some black cabs but this isn't waterproof like the J12 so would reduce mud plugging ability!
so looks like i'm going to have to fabricate a new engine mount. Wish I'd done a bit more research before starting as the 200TDI from the disco seems an easier and more popular swap, ah well, hindsight is wonderful!
