Jul 13, 2009 17:51:38 GMT
I'm tring to make some progress with my turbo conversion (slowly!) I still need the oil feed, so................
What internal diameter do oil feed turbo need to be?
I've worked out what oil feed fitting they need. Just wondering if anyone knows a good/cheap companies who makes hoses?
I need 2 hoses -
Block to t-piece with 1/4 npt fittings, one end male, one end female. 10cm long.
T-piece to turbo with with 1/8 npt fittings, one end male, one end female. 30cm long.
Any advice or input welcome?
pjw
Jul 13, 2009 18:02:19 GMT
don't you need a return too? Should be easy to do if you have a turbo sump, if not just drill and tap your current one.
Diagonally parked in a parallel universe
B-8-D
down to one car!!
Jul 13, 2009 18:11:39 GMT
robin I'm happy your getting on with the turbo conversion... cant wait to see it done.. hopefully I will be helping my bruv do his new sierra soon... the feed line deosnt need to be too big just the next size up from brake line sized goodridge but I cant remember what size that is... doh.. its more important to have the pressure it desnt need too much flow tbh.. but make sure the return is big enough.. about 1/2" internal will do it there is a plug on the block that can be used for a decent drainback... have you explored this site?? skogenracing.editboard.com/englis....-howto-t657.htmcool mad stuff there.. si as for companys that make hoses try braided steel/goodridge/ or places like pirtek etc... si
Last Edit: Jul 13, 2009 18:16:49 GMT by B-8-D
Jul 13, 2009 19:32:22 GMT
don't you need a return too? Should be easy to do if you have a turbo sump, if not just drill and tap your current one. or even use the dip stick tube! will be good to see the turbo malarky get under way... are you planning on just going with a low boost on the standard motor?! ;D ;D cant wait to make a start on mine now, looking forward to a weekend of lowering and stuff with si....!
or even use the dip stick tube! Unfortunatly it's on the wrong side of the engine Oh well taking the sump off and welding a pipe on isn't that hard, well within my remit as for the drain the turbo came with a drain already, so that okay.
Jul 14, 2009 11:34:07 GMT
Jul 14, 2009 12:38:24 GMT
Don't get me wrong I'd love a YB, but I'm poor which is why it's taken me this long to get to this point! I've got this to go on my 2.0 Pinto........ It's a T3 (not a watercooled one thou), but what it's off or where it's from I've no idea, the manifold is definatly a pinto one ;D I've researched it fairly well, going to run standard compression, retard the ignition and run 6 psi of boost with an adjustable fuel pressure regulator. The oil feeds and down pipe is the only thing holding me back now!
Colonelk
Club RR Member Number: 83
Jul 14, 2009 13:38:04 GMT
The oil feeds and down pipe is the only thing holding me back now! So get it done then! ;D (I cant wait to see it done is why )
Last Edit: Jul 14, 2009 13:38:44 GMT by Colonelk
Jul 14, 2009 17:01:06 GMT
Don't get me wrong I'd love a YB, but I'm poor which is why it's taken me this long to get to this point! I've got this to go on my 2.0 Pinto........ It's a T3 (not a watercooled one thou), but what it's off or where it's from I've no idea, the manifold is definatly a pinto one ;D I've researched it fairly well, going to run standard compression, retard the ignition and run 6 psi of boost with an adjustable fuel pressure regulator. The oil feeds and down pipe is the only thing holding me back now! Fantastic. I have a T3 on the race car and mine isn't watercooled either. Go for it. Charlie
B-8-D
down to one car!!
Jul 14, 2009 22:26:55 GMT
The oil feeds and down pipe is the only thing holding me back now! well bring it up to my work for a weekend and wee will get it done then.. a few hours work and we will get it singing.... si
