I'm all up and running with my lathe in my garage, well all except the suds pump, I did have a pump sorted but it now turns out its unsuitable as it needs a head pressure before it will pump, and I'm not really wanting to chop the lathe about to fit it,
So I have been thinking, I know a worrying situation, whats to stop me using a normal external 12v FI pump [cos I have one] and dropping it in the tank, obviously with suitable filtering attached, the voltage concerned should not give any electrical problem, the suds mix will give the lubrication and the pump will certainly have the volume I need,
the major + side as I see it, I have not got 240v electrics anywhere near the suds as I can mount a cheap 12 transformer in the control box out of the way.
ian ;D
ian ;D
