Had loads of pm's about things and so many people wanting to dibs things and take to RR09 , so what I'm going to do is leave everything for sale until I recieve payment or its getting confusing , also more stuff added and pictures online at
community.webshots.com/album/573456169kmNYtk
Terry 07877 024871
1 electric engraver £10
2 Amtec compression tester in case £20
3 letter & number punch set in case £10
4 Impact Driver and bits in case £5
5 Multi meter set with screwdrivers/soldering iron and accesories in case £20
6 Spring clamps £5
7 hub puller 3 leg £5
8 Set of 8 HT lead testers and plug tester £10
9 Medium valve spring compressor £5
10 Big roll can toolbox Draper SOLD
11 Easyheat propane space heater with big half full bottle £125
12 Big compressor £100
13 Class 430 battery charger/starter £40
14 Industrial pillardrill £50
15 strong heavy workbench with vice fitted 5ft x 2.5ft SOLD
16 6 wheel car creeper £5 SOLD
17 2 ton folding engine crane hardly used £150
18 Halfords 4 drawer step up box 26"long 12" deep no key £40
19 big pipebender with formers SOLD
20 Como mini drill in case £5
21 weller soldering iron in case £5
22 Black decker hot air gun £5
23 Black decker angle grinder £5
24 Mckeller 14.4V cordless drill in case £5
25 Mckeller palm sander in case £5
26 Huge 3/4 drive socket set in case 19mm-50mm £25
27 Big heavy duty axle stands up to 34inches SOLD
28 2 ton trolley jack in case £15
29 Sealey 3 ton trolley jack £25
30 wickes pillar drill SOLD
31 wickes table saw £20
32 4 drawer filing cabinets £5 each
33 4ft Hi lift farm jack £20
34 8 x 1 litre underbody shultz £10
35 2 litre ford radiant red 2k gloss paint , new £20
36 Basil hoover (like henry) workshop use £10
37 Case of wood screws £10 (case alone is £15 in b&q)
38 approx 100 tool clips various sizes £10
39 3 litres brush on underseal , 1 been opened £10
40 loads of electrical connecters, tape , blocks etc £10
41 air cut off tool £5
42 air grinder £5
43 air chisel £5
44 air saw £5
45 air ratchet 3/8 drive £5
46 Sealy spray gun 1.7 nozzle suction fed £20
47 Upol spray gun 1.7 nozzle gravity fed £20
48 Various tubs of genuine metalflake and glowble
49 Silverline polishing mop £10
50 Various cd players all untested £5 each
pioneer DEH-615
ministry of sound
sony cdx c5000 no wiring plug
kenwood kdc3021 no wiring plug
jvc kds636 no wiring plug
51 Various Amps all untested £5 each
Jet sound 200w
tornado 500w
philips 600w
terminater 500w
52 CB swr meters both with patch leads £3 each
53 6x4 sheet of stainless steel , 2inch square missing from 1 corner , thickness unknown £30
54 12V impact gun in case £15
55trolley on wheels with bench grinder SOLD
56 wickes flat sander £5
Terry 07877 024871
6 Spring clamps £5
42 air grinder £5
43 air chisel £5
44 air saw £5
pioneer DEH-615
ministry of sound
Jet sound 200w
tornado 500w
philips 600w
terminater 500w
55
