Sorting a few things out as I'm finishing my house as it's up for sale so need to get rid of stuff I don't need/won't be taking to Slovakia.
Bosch PWS 720-115 Angle Grinder 4.5". This is quite new as I bought two Bosch Blue ones shortly after. Fitted with an anti vibration handle from a 9" grinder - I had the thread reduced so I could use it on my 4.5" ones. Will include the cutting disc as I'm too lazy to take it out. £18.00
Bosch PWS 6-115 Angle Grinder 4.5". I'll be quite honest this was my first grinder so has had a lot of use. Still works ok though but getting on a bit. With include the knotted wire wheel with it, also have the spanners for it. £8.00
Pittarc 0.8mm Welding wire. 15kg reel. In box and still sealed in plastic bag so not corroded. £18.00
Bosch PSB 12 VE-2 cordless drill. With charger, I have the battery but was stiffed (Ebay) as it doesn't hold a charge so it needs a new battery. £10.00
Master Mecanic 2ton trolley jack, a bit care worn but still works ok £4.00
Wickes Oil Filled Radiator, has a broken wheel but otherwise ok £6.00
Clarke CFC100 1tonne folding crane, legs can be removed completely if required so easier to store and transport. Used a few times only. Has a couple of good straps with it as well £90.00
Can post some items but prefer collection from Barnsley or Rotherham.
