Dez
Club RR Member Number: 34
I have 2 of these kits f/s. the first one is very clean, looks almost new, but is missing the fan mounting brackets and the controller knob(not a problem, I can turn it by hand even with it missing), the second one is older/dirtier but is complete with knob and brackets. both work fine. spec- kenlowe klm1702 12" fan, 12 volt. 4 mounting holes on motor baseplate. kenlowe 'variamatic' thermal fan controller. basically an adjustable thermosat/fan switching relay. capillary type, you mount sensor inside top hose. retail is slightly over £100 for a fan and controller kit. I want £45 each kit, posted. do your motor a favour and ditch that power-robbing viscous fan;)
Last Edit: Jul 1, 2009 17:42:30 GMT by Dez
Hi Dez, you have a PM
Dez
older/dirtier kit now sold subject to payment. other ones still here......
How do you fit this, as it would be nice to upgrade the Toledo
1993 Fiat Panda Selecta 2003 Vauxhall Combo 1.7DI van 2006 Mercedes Kompressor Evolution-S AMG SportCoupé
"You think you hate it now, wait til you drive it"
Dez
pull off and throw away viscous fan coupling, fan + shroud. bolt leccy fan on in an appropriate place- about 1/2" from rad matrix, as high up the rad as poss- may need to make some simple flat plate brackets to do this depending on application. pull off top hose, slip in sensor, bit of ptfe tape to wrap/seal sensor wire to pipe stub, refit pipe+ tighten. screw controller down somewhere appropriate in engine bay- I had mine on the side of the battery tray. wire controller to fan + a live feed- can be direct to battery as controller will cut fan off when water temp drops below whatever level you set it at, not when ign is turned off- thats how I had it set anyway to prevent heatsink. set temp you want it to switch on/off at on control knob, job done.
Last Edit: Jul 3, 2009 20:00:00 GMT by Dez
Ok, going to check moolah, and back to you, but i am very interested . What with this and the electric ignition, the car should be perfect
Ok, going to check moolah, and back to you, but I am very interested . What with this and the electric ignition, the car should be perfect My thoughts entirely, that´s why i bought the other one Money is on it´s way Dez
Dez
Jul 11, 2009 17:16:38 GMT
bump. will be posting yours to grizz on monday dave, had a busy week and not got to postie yet.
Jul 11, 2009 18:41:07 GMT
Hi dez I will take the other one. Pm on its way
Rover P6 3500S British beef Moo!!!
Jul 11, 2009 19:49:02 GMT
Sorry 2nd dibs after Pandaselcta. didn't mean to push in, got excited!
Dez
Jul 11, 2009 19:52:43 GMT
have replied to your PM henry. not had contact from anyone else, first person to pay gets it as with all my items
Jul 11, 2009 20:06:20 GMT
Forgot about this, will leave it for henryv8 though if he wants it (put me as second dibs
Jul 11, 2009 20:15:48 GMT
Thanks PandaSelecta, Monies sent.
bump. will be posting yours to grizz on monday dave, had a busy week and not got to postie yet. No hassle mate, cheers.
