rs2kpete
Old FORDs Never die they just get faster
Jun 28, 2009 10:21:30 GMT
cosworth granada 2.9v6 24v breaking (BOA)
all must go manual con so it has a type 9 box full leather int VGC 2 sets of wheels RONALs new KYB shocks also a set of 4X4 5stud wheels with tyres simular to the RST s1 wheels £150
PM or email peter.jessup@lineone.net for info & prices
Last Edit: Jun 28, 2009 22:09:35 GMT by rs2kpete
Jun 28, 2009 17:14:15 GMT
Hi Pete,
is the box a standard Type 9 or a modified one for the 24V and is it a 5 speed.
Did you have to modify the loom once the autobox was disconnected?
cheers, Dave
rs2kpete
Jun 28, 2009 22:04:30 GMT
:)the box is a type 9 5speed with v6 bellhousing thats all I know guess it's from a xr4i you need to fit the VSS to the speedo drive to keep the ECU happy on a granada
You have a P.M.
rs2kpete
Jun 29, 2009 15:37:27 GMT
ODDBUS I have replied
Jun 29, 2009 21:24:23 GMT
Ooooh! Is the 5spd on a cologne V6 not suitable for the 24v BOB's then? If so I've made a boo boo & would like to request 2nd dibs on this one if OB doesn't take it...
Cheers!
HC.
IDY
Jun 30, 2009 10:25:57 GMT
Ooooh! Is the 5spd on a cologne V6 not suitable for the 24v BOB's then? Which type? there are 2 (more if you count the 4x4 versions) The later MT75 normally found on the 2.9 is fine bolted up to the 24v. The problem is that the V6 RWD version is rare in the UK. People normally make one up using bits from a V6 4x4 box and a 4 pot box. The Type 9 is not really designed for the power of the 24v and is relatively easy to break when bolted up to the 24v. There are mods that can beef up the box to take more power/abuse
I will get round to finishing it at some point
rs2kpete
Jun 30, 2009 20:02:44 GMT
ITS THE V6 TYPE 9 % SPEED NO SOLD !!!
Box is mine Cheers Pete!
Davenger
It's only metal
Club RR Member Number: 140
How much for the pedal box?
milan
How much for the crankshaft position sensor? Posted to Ireland?
rs2kpete
How much for the pedal box? Hi Dave it's a manual one £35 inc all the bits & clutch cable
rs2kpete
How much for the crankshaft position sensor? Posted to Ireland? Hi Milan the CPS is £40 posted as they are a mint from Fords
Davenger
It's only metal
Does that include postage Pete?
milan
How much for the crankshaft position sensor? Posted to Ireland? Hi Milan the CPS is £40 posted as they are a mint from Fords He got one delievered from the UK already man,it should be here tomorrow,but if hes stuck for any other bits I'll be onto you straight away,thanks.
rs2kpete
Does that include postage Pete? Hi dave no sorry P+P will be about £8
rs2kpete
Hi Milan the CPS is £40 posted as they are a mint from Fords He got one delievered from the UK already man,it should be here tomorrow,but if hes stuck for any other bits I'll be onto you straight away,thanks. OK No Prob
rs2kpete
bump lots of parts to go ?
milan
Jul 12, 2009 23:49:19 GMT
Back again! Hes caught badly for a Crank pulley,(twin belt toothed pulley),have you still got one Pete?
Pm sent anyway.
Thanks.
