Advertised on behalf of a friend. Please PM me if interested.
Here we have a freshly built high spec 1293cc short engine for sale due to a let down by a customer.
The spec is:-
Sporting the superior 6581 turbo crank
CNC bored and honed to 0.020" within a tolerance of 5 microns.
All oil gallery plugs pulled, replaced with hexagon plugs and fitted with new core plugs.
OMEGA 10cc cast pistons
ARP Rod Bolts
2 bolt centre main strap
New oil pump
New cam followers
New main bearings, big ends and thrusts.
Avonbar Phase 2 cam timed in precisely at 108 degrees
Steel duplex timing gears and chain, complete with cover, seal and crank damper etc...
Including with this is a ultra light steel flywheel with pre-engaged ring gear, backplate with lugs machined 1.5mm for more clamping load, triple drive straps, all new bolts, AP Race clutch plate, double grey cover, the whole assembly has been balanced to 10,000 rpm although not that you should get it there.
This engine with the right cylinder head, turbo, gearbox, drop gears etc is capable of producing 200bhp plus
This engine would also be suitable for supercharger applications.
This engine in some go faster speed shops would cost you in excess of £2000 VAT check it out!!!
The price is £1750 !!exchange!! buyer collects or can meet within 100 mile radius of Pontefract, West Yorkshire.
If you want a modified cylinder head to compliment this engine it can be arranged at extra cost.
Please PM me if you are interested!!
The spec is:-
ARP Rod Bolts
New oil pump
New cam followers
