took this motor out of my truck as I'm fitting a rover v8, thought it was the head gasket that went, but me being a numpty didnt realise the rad cooler for the ATF had cracked in the radiator casing.
was still running when it came out on wednesday and the carb is still attached
might be of use to someone
best you collect it, its 1 heavy mother !!
range rover classic autobox+torque converter, only missing a transfer box for the 4x4 gear
all working and in great condition, only done 89k miles
looking for £50 ( the torque converter is worth that alone , i just need it out the way)
make me an offer/swap/whatever on the engine
located in kent, just off the M25 J2
