fatlad
Nov 24, 2009 23:47:46 GMT
lol cheers!
made a "rolla-ma-jig" today outof a pallet and some big castors so i can trundle it about the garage and make it do 360's lol.
not much else, hoping to sort a metro frame this weekend and a starter so i can get it firing!
lol that sounds like dangerous fun not to trust fatlad with . get in it and let someone spin you round haha
78 Kadett C 2.0 8 valve turbo, holset, rust&other stuff..
Nov 25, 2009 12:41:06 GMT
I'm sure I've seen this car at the top of brockle-bank up before caldbeck no?
This isnt coxy is it?!?
Jordan
fatlad
Nov 25, 2009 17:55:11 GMT
yer its chris! jordan r? what you driving nowadays?
fatlad
ALERT: don't use pallets for "rollamajigs" ! the castors snapped off mine at one end and it was sat with its nose in the air! lol no damage though!
Random!
Still got the stilo, but I'm running my RX8 at the minute and the signum for motorway journeys lol
I've got a project on here too - My morris minor pickup
Saw you at the dragstrip last time I was there but never thought to say hi lol
Mini's looking well, you still at uni?
Jordan
Last Edit: Dec 2, 2009 12:57:11 GMT by tedjordan
fatlad
finally got a metro subframe at the weekend so I thought id have a go at fitting it up tonight! started off by stripping all the steering rack off the back of it. then tried it for size! seemed to fit up better than I could have hoped! hardly any mods to the bulkhead yet! just has to trim the edge where the two skins overlap under the shock mount. took off the hydragas cans and used one of the plates as a template to mark out for the side plates. then marked where the holes for the shock mounts where meant to be. this was all done very technically using a set square and a skrewdriver scribe! lol 1st attempt had the frame to far back so tryed again with another shot. got it spot on so tacked the two together and used one as a template. then fitted it up! looks to be in the right place! I tested it by jumping on the front of the subframe and it didnt fall off yet, will add floor braces and weld the sideplates to the bulkhead after some trimming down to save some weight as their made of 5mm steel and are heavy!!! using the metro subframe as opposed to the mini means i get proper suspension (wishbones) Win ;D! and it makes fitting the k-series a whole lot easier! just need some mgf driveshafts and to cook up some engine mounts and i should be cooking! cheers, chris
Last Edit: Dec 3, 2009 0:57:08 GMT by fatlad
Good stuff fatlad, awesome work ;D It's crazy how simply they're put together! Will be interesting to see where you brace it all
Last Edit: Dec 3, 2009 1:08:47 GMT by lolface
fatlad
so tonight i got a bit more done on the car. trimmed off the old steering rack mount and a few of the tabs off the bulkhead. then started on making the floor mounts, decided to make them out of some tube i had kicking around. made the plate that sit against the bulkhead out of some fat 5mm plate ;D should do the job! then started on the tower mounts. chop chop! also cut the hole for the for the steering column to meet the rack. getting there!
Good work!
Did you see the Kseries turbo mini on the 16v mini forum?
Koos
fatlad
thanks! yer, that car is mental! didnt he have like 300hp from a 1.4? i think hes gone to a 1.6/1.8 now.
Something like that - bog standard scrapyard motor apart from a thicker head gasket :-)
Koos
Dec 10, 2009 13:03:39 GMT
You're moving at a decent pace with this coxy lol. If you ever need any bits or pieces my uncles got a load of mini spares down off wigton bypass where my workshop is and right next to it theres my other uncles fab-shop so theres a ton of decent size off-cuts etc you're welcome to if you need any bits and bobs.
When you expecting to see her running?
Jordan
fatlad
Dec 10, 2009 16:21:39 GMT
ooo... ill have to pop down and have a ganders at that moggy of yours it looks like a beast! no deadline as such just want to take my time and do it right hopefully! would be nice to have it back for next summer to do some trackdays etc. well just have to wait and see... been making big plans for the rear suspension so it might be a while yet!!! you still working at mfl?
Last Edit: Dec 10, 2009 16:22:04 GMT by fatlad
Dec 10, 2009 16:54:12 GMT
can't go wrong with the vvc engines. proper good engines
'Simplify and add lightness'
'To add speed, add lightness'
