if any of you are anything like me (then you need medicating) you probably have a few? websites in your favorites either relating to you past or present projects so perhaps an idea would be to share these with the rest of us as often i have only found usefull info by following a link from a reply so as a start here are a couple i have found usefull in the past
www.carlsalter.com/motorcycle-manuals.asp
this gives free downloads of mc manuals (handy for those of us that only need two wheels to have fun
www.the12volt.com
lots of electrical info wiring alarms cruise and sound systems
and finally if you have had a bad day and want to see that things could be worse in an automotive way
www.wreckedexotics.com/
well unless it is your exotic pictured (there is also a retro section)
ttfn glenn
ps i am sure i don't need to say it but only retrorides type sites not the most common sites found on the web
www.the12volt.com
ttfn glenn
