May 21, 2009 18:39:43 GMT
i have just got one of these and need a little advice on the suspension, i don't want to have it so low i have to avoid the speed bumps and mess up what peugeot did, any help would be cool
MK2 Cortina Estate
May 21, 2009 18:49:46 GMT
Same as all 205`s...lowering springs on the front and adjust the torsion beam on the rear - this is cheap job and assuming the torsion beam isnt seized to hell, not difficult either, then add a set of 4 decent dampers. 205`s handle well as stock, and excessive lowering kills the handling on all but the smoothest of roads. For practicality, I wouldnt go lower than a 40mm kit. 60 at the most. My old GTi was far too low for comfortable road use, but on track it was awesome.
filmidget
East Midlands
Mostly Lurking
May 21, 2009 19:06:09 GMT
Oooh nice! Some inspiration? I reckon 205's are a car that look good without scraping the floor - mine will be staying on standard springs but with a nice set of bilsteins.
'79 MG Midget 1500 - Still patiently awaiting attention '02 Vauxhall Astra 1.8 Elegance(!) - Better than you might think '03 Mazda MX5 - All new and shiny looking (thanks to Antony at Rust Republic) '09 Renault Clio - Needs to go.
May 21, 2009 19:54:31 GMT
Around 30mm down is good. A good road spec setup would be:
OE Bilstein 306 GTi-6 dampers - about £150 Eibach 106 sportline springs - £75 205 GTi torsion bars - £20 2nd hand Saxo VTS 22mm rear ARB - £40
That'll give you a very good road setup for less than £300!
May 21, 2009 21:13:55 GMT
thanks for all the advice guys, so how do i go about changing the rear torsion bar ?
MK2 Cortina Estate
