May 20, 2009 12:44:58 GMT
Open to offers on all items.
List updated below
All parts are new and have been mounted but not used. If you require more info and pics of any items please email.
All parts located in Halesowen, West Midlands
Call Pete on 07595 880040
bigkev
chillin
May 20, 2009 14:54:14 GMT
HI pete - can I see a photo of the large oil cooler and the ali rad catch can please
Cheers
Kev
May 21, 2009 11:48:41 GMT
ill post a pic tonight. measurements for oil cooler are 13.5" wide by 10.5" high by 1.75" thick
May 22, 2009 13:54:13 GMT
SMALL 75A ALTERNATOR (CAN BE REWOUND TO 150A) APPROX 4.5" DIA, 5.75" TOTAL LENGTH, 6" BETWEEN BOLT HOLES. BRAND NEW. BOXED. £150 O.N.O ALUMASTAR WHEELS AND MICKEY THOMPSON SPORTSMAN SR TYRES. 3.5X15". 5X4.75" PCD. BRAND NEW. £850 O.N.O CLARKE 8" WETSTONE BENCH GRINDER. £25 O.N.O VHT HIGH TEMPERATURE BRAKE CALIPER PAINT. GLOSS BLACK BRUSH ON 236ML. £12 O.N.O FORD GRANADA / SIERRA FLEXI BRAKE PIPES. 3 PIPES (VECO VR304 BFH4949) AND 2 PIPES (VECO VR302 OR BFH4357) £12 O.N.O SUSPENSION BUSHES WITH BRASS INSERT AND BOLTS (X4). SEE PIC FOR SIZES £20 O.N.O BRAKE CALIPERS. TWIN 44MM PISTONS. SUIT 12MM SOLID DISC. 1.5KG EACH. APPROX 88MM BETWEEN MOUNTING BOLTS. £30 O.N.O PAINLESS WIRING ENGINE SHUTDOWN RELAY. USED TO STOP ENGINE OVERRUN. NEW. UNUSED. £60 O.N.O DRAPR 2 TON TROLLEY JACK. 135-342MM LIFT. AS NEW £13 O.N.O BRAND NEW FUEL FILTER TO FIT MOST VEHICLES. £5 O.N.O POLISHED ALUMINIUM GREASE CAPS TO SUIT 2.8 CAPRI HUBS. MAY FIT OTHERS. 47MM DIA' £12 O.N.O BONNET HINGES AND RAMS FROM VAUXHALL VECTRA. CAN BE USED TO HINGE YOUR BONNET, TRUNK ETC. £8 O.N.O FORD MONDEO HANDBRAKE CABLES (X2) SUIT SALOON WITH DISC BRAKES. 1994 ONWARDS £15 O.N.O GM BRAKE PADS. P/N 90399495. CALIBRA 89-97, CAVALIER 89-95, VECTRA 96-02, ASTRA 85-93, CARLTON 87-93 £8 O.N.O SEALEY BENCH DRILL (P/N SDM30) £60 O.N.O RCI 5 POINT HARNESS (X2). 3" STRAPS. MANUFACTURED AUG 2006. SFI SPEC 16.1. 82" SHOULDER STRAPS. BLACK £175 O.N.O VAUXHALL HEAD GASKET TO SUIT 1.4 / 1.6 16V DOHC ENGINE, 1998 ONWARDS. £8 O.N.O ROCKER COVER T-BOLTS (X11). 100MM LENGTH + 25MM THREAD £8 O.N.O PIONEER DOOR SPEAKERS. 5" 80W. 2 WAY. TS-G1310 £12 O.N.O QUICK RELEASE STEERING WHEEL BOSS + COLUMN TO SUIT. SUIT MOUTNEY STYLE STEERING WHEEL. £20 O.N.O MAF SENSOR TO SUIT VAUXHALL C18SEL, C18XE, X18XE, X18XEL, X20XEV, C22SEL. REPLACED MINE DUE TO INCORRECT ERROR CODE. FULL WORKING CONDITION. £25 O.N.O WASHER BOTTLE KIT £20 O.N.O GM SENDER UNIT. ADJUSTABLE 6" TO 24". INCLUDES FITTING KIT. BOXED (NO PIC YET) £60 O.N.O
10mpg
Club RR Member Number: 204
May 22, 2009 21:11:10 GMT
I'm interested in the T-bolts what thread are they I think my Ford V8 is UNC but I'll have to check...
If they'll fit I'll have 'em!
hi chap, how 'deep' is the mountney quick release adaptor? I want one but don't want the steering wheel in my face lol! Thanks!
Last Edit: May 23, 2009 8:04:04 GMT by lolface
78 Kadett C 2.0 8 valve turbo, holset, rust&other stuff..
May 24, 2009 10:24:42 GMT
djivesp. the mountney quick release is 41mm deep. I also have the steering column to go with it but that would cost a fair bit to post.
10mpg. not sure what thread they are. I bought them off John Reid years ago with intention of fitting them to my 400m small block ford engine but sold the car.
dugong
One Of Us Will Live To Rue The Day We Met Each Other (Wire : 2008)
May 24, 2009 13:48:45 GMT
Where are you based h0trodder?
Would be keen on the trolley jack.
May 24, 2009 19:20:06 GMT
I'm based in halesowen, west midlands
10mpg
May 24, 2009 23:06:52 GMT
djivesp. the mountney quick release is 41mm deep. I also have the steering column to go with it but that would cost a fair bit to post. 10mpg. not sure what thread they are. I bought them off John Reid years ago with intention of fitting them to my 400m small block ford engine but sold the car. Sounds good chap! I'll take a punt on them! how much posted?
May 26, 2009 10:16:43 GMT
best place i can find for delivery of trolley jack or column & quick release (due to the weight or size) is parcel2go / dhl. that would cost around £9.
May 26, 2009 17:09:47 GMT
djivesp. the mountney quick release is 41mm deep. I also have the steering column to go with it but that would cost a fair bit to post. 10mpg. not sure what thread they are. I bought them off John Reid years ago with intention of fitting them to my 400m small block ford engine but sold the car. Sounds good chap! I'll take a punt on them! how much posted? call it £10 inc postage for the t-bolts. you can pay me via paypal / cheque etc
bttt as advert edited and updated
10mpg
yup email me your paypal details and i'll send you some dough..
that is a lovely set of wheels
Prices reduced on following items:- Alternator (is actually 40a, rewindable to 100-150a) - £100 Strange 9" centre section - £900 Alumastar wheels and Micket Thompson tyres - £800 Suspension Bushes - £15 Brake Calipers - £20
calipers and bushes sold.
items remaining Alternator (is actually 40a, rewindable to 100-150a) - Brand new, cost £150. Sell for £100 Strange 9" Aluminium centre section - £900 Alumastar wheels and Micket Thompson tyres - £800
wheels sold. hurry if you want anything else as I'm packing it for shipment next week
