Seth
The Minx is wearing a set of what I was told are 105E Anglia wheels, 13 x 3.5 I think. These in fact. I was wondering if there were wider ones available other than Lotus rims (which would be too expensive I expect). Lotus are 5.5 aren't they? Were 4.5's or 5s fitted to anything originally? Don't want anything newer looking by the way, so no dartboards/rostyles etc Google search for wide steel wheel ;D
Last Edit: Apr 30, 2009 8:41:09 GMT by Seth
I think most of those style rims on escorts were pretty narrow, ours came with 155's on and they weren't stretched, might be cheaper to get your centres fitted into 5.5j Mex/RS2000 steel rims? (I think capri Lasers had some widish steels as well)
Ford SteelsDeleted
@Deleted
Apr 30, 2009 10:28:33 GMT
Pretty sure standard Anglia wheels are 4.5J not 3.5. Lotus ones are 5.5J and there's a super rare expensive 6J.
Escorts came with 12" steel wheels as well.
Apr 30, 2009 10:37:30 GMT
Capri Lasers had a 5.5j steel rim that looks like an early FWD Escort rim. There is also a plain non-dartboard/tinnilite rim that was used on MKII Escorts, Cortinas and Capris which I think was a 5j. MKII XR2s came with a steel rim as standard instead of a Pepperpot that must have been quite wide 5.5-6j too but I'd imagine they are quite rare.
Later Escorts had a 5x5 x 14" if you don't mind going up a rim size. They look like a scaled up version of the plain MKII Escort rim.
Jaguar S-Type 3.0 SE
Ford Steelsdreadnort
@GUEST
Apr 30, 2009 10:38:52 GMT
Mk1 Cortina GTsand Corsair GTs had 41/2s and Mk2 GTs had 5s. There were also Weller Colts in many widths up to 10j if you can find any.
Ford Steelsbriandamaged
@GUEST
Apr 30, 2009 11:03:21 GMT
Early-70's Escort Sports were fitted with 5" wide standard steels...they do have holes round the outside though, like Escort Mexico steels did, only with less dish.
Later Mk2 Escorts had a wide-offset 5" rim as already stated, but I think they'd probably be too offset for your Arrow They had almost as much dish as a Lotus rim, only with less overall width.
Seth
Apr 30, 2009 11:18:09 GMT
Thanks for all the info. Really wouldn't want anything with holes. Just something like the ones I've got but a bit wider. May just keep my eye out over the summer.
mk14dr
Yorkshire and The Humber
Club RR Member Number: 85
Ford Steelsmk14dr
@mk14dr
Club Retro Rides Member 85
Apr 30, 2009 11:29:09 GMT
drum braked escorts came with (I think) 4.5x12 plain fronted steels (of which I have a set of 4 with hubcaps.... I think ) IIRC they look pretty similar to those anglia ones that your running at the moment, but I can double check when I get home tonight if you want
Ford SteelsDeleted
@Deleted
Apr 30, 2009 11:34:47 GMT
IIRC they look pretty similar to those anglia ones that your running at the moment, but I can double check when I get home tonight if you want Yes, they look identical, then when you try and put them on the car for stolen off your brother's car comedy skinny crossply look they don't clear the caliper ;D
mk14dr
Ford Steelsmk14dr
@mk14dr
Apr 30, 2009 12:41:36 GMT
Ah yes, I'm forgetting why I don't run them since I upgraded to discs. They'll be no good for the humber then
Apr 30, 2009 12:51:14 GMT
My ex's 1300XL had 12" rims and teeny tiny disc brakes that did fit behind them when we first bought it.
kenb
Apr 30, 2009 13:03:25 GMT
try corsair wheels or even standard cortina wheels for 4.5"x13.
Standard fitment Anglia rims were 3.5" though certain spec models were fitted with 4" namely some vans and estates.
Seth
Apr 30, 2009 13:06:57 GMT
try corsair wheels or even standard cortina wheels for 4.5"x13. Standard fitment Anglia rims were 3.5" though certain spec models were fitted with 4" namely some vans and estates. Thanks KenB Hmm, wonder if Imperal has the rims off his Corsair. I think I'd have serious scrub line issues even if 12"ers did fit. Just thinking about a second set done in a slightly different way.
Apr 30, 2009 13:56:31 GMT
JamesP.
