dubzi
Here's a thing......
My Ambulance is way too high at the back. I have a double leaf spring with the axle mounted under it. The shock absorber mounts point downwards and I had to order the longest shocks possible from Adrian Bailey.
Saw an axle on ebay the other day and the shock mounts pointed upwards. It was off the van on a pallet, so it's possible it might be upside down! It occurred to me though that mine might be. Or even if it's not, what if I turned it upside down? It would mount on top of the springs then and the shock mounts would point upwards. Would that work or would the brakes be all backwards and not work? What's anyone reckon?
Happiness ain't at the end of the road. Happiness is the road.
Hmm ok, so the van will need arches..... what are the wheel dimensions and tyre sizes?
RE diff, I guess the sure way of telling is looking at the diff drain plug.
Apr 30, 2009 14:14:48 GMT
Here's a thing...... My Ambulance is way too high at the back. I have a double leaf spring with the axle mounted under it. The shock absorber mounts point downwards and I had to order the longest shocks possible from Adrian Bailey. Saw an axle on ebay the other day and the shock mounts pointed upwards. It was off the van on a pallet, so it's possible it might be upside down! It occurred to me though that mine might be. Or even if it's not, what if I turned it upside down? It would mount on top of the springs then and the shock mounts would point upwards. Would that work or would the brakes be all backwards and not work? What's anyone reckon? don't turn the axle upside down, you will be able to go backwards with four gears and forward with one.lol. you can relocate the axle on top of the springs but you will need to make new spring mounts and weld them on. but be aware that this might make the diff smack the bottom of the floorpan.
Apr 30, 2009 14:17:36 GMT
cheers gray , much appreciated, I learnt most of the skills I have from my eldest brother whos is a metal work guru. believe it or not I'm a refrigeration engineer by trade , one day I would like to have my own unit and do vans/classics/vw resto all the time. still looking for a unit though. not cheap though are they.
Gray
Silence isnt golden!!!
Apr 30, 2009 18:45:18 GMT
Hmm ok, so the van will need arches..... what are the wheel dimensions and tyre sizes? RE diff, I guess the sure way of telling is looking at the diff drain plug. I cant recall offhand but should be over at the van in the next couple of days so will check then aqua-genius, workshops are a big expense, the one the vans in there was big and me and a mate were shelling out £580 a month for it, i was holding a full time job aswell so never really got the benefit of it. I worked for myself years ago as a mobile welder/fabricator and alot of my work was deep sea trawlers but i did alot of cars/tractors/lorries aswell. folk restoring them could have their resto worked on as money allowed, didnt have the hassle of trailoring etc. and through watching and helping furthered their own skills. My customers loved the service and i was a happy bunny doing it. everything you could possibly need will fit in a 110 landie
dubzi
don't turn the axle upside down, you will be able to go backwards with four gears and forward with one.lol. you can relocate the axle on top of the springs but you will need to make new spring mounts and weld them on. but be aware that this might make the diff smack the bottom of the floorpan. That's kind of what I thought might happen. God knows what sort of stupid axle/spring combination I've got. The back end is way too high. The rear step is at least 2 ft off the ground! Probably best sourcing an axle with springs. Not that simple though as there's quite a few variations.
dubzi , its quite possible that you will have slipper springs on the rear of your amby, smoother ride for the meat in the back on the stretchers.lol. measure between the spring eye holes , you might be able to use tipper springs like me and lower the van that way. don't forget your amby would have been laiden down with medical equipment so it would have been carrying a fair bit of weight too.
Hi iv got my self a bedford cf camper 1983 deisiel manual. And there is a problem with the diff so I'm looking for a complete axle does any one know know what alxe will fit this old camper iv been looking on internet and still havent come up trumps please could anyine help thanks jim
Mega thread resurrection! I don't know what your asking though.
Always cf axles on ebay. Are you trying to find out the ratio or what other axles might fit?
