I have a set of 7" Allycats which I want to put on my car. Am looking to put 185 or 195 width tyres on. Does anyone have any idea if a 185 will be stretched too much over a 7"? Ideally I would like to use 185 on the fronts and 195 on the back, but if 185 will give too hard a ride because they are stretched then I should go 195 all around (if they fit under the arches). Cheers
Last Edit: Apr 21, 2009 8:53:46 GMT by cobblers
stretch is like soo last year..... lol
I reckon that a 185 on a 7"should be fine...very little stretch, if any. Here's some 185/60 on a 7x13: None of those look like they're going to be detrimental to ride quality to me!
CIH
stretch is like soo last year..... lol good
stueyt
Saving cars from the scrapyard.
stretch is like soo last year..... lol Never did get the idea/point of that. Cheers, Stu.
Always looking for the next project!
Are they 13s? If so you'll either have to go with 185s all round or 195's all round - the reason is because the smallest 185 you can get is a 185/55, and the only 195 tyre in 13" is 195/45. Hence if you put 185/55 on the front and 195/45 on the rear the rear tyre will be a lot smaller in diameter so will look daft.
Matt
Apr 21, 2009 10:53:42 GMT
Are they 13s? If so you'll either have to go with 185s all round or 195's all round - the reason is because the smallest 185 you can get is a 185/55, and the only 195 tyre in 13" is 195/45. Hence if you put 185/55 on the front and 195/45 on the rear the rear tyre will be a lot smaller in diameter so will look daft. Matt Can you not get 195/55 R13s any more? They were standard fit on R5GTTs IIRC. EDIT: Mytyres throws up a 195/55.
Last Edit: Apr 21, 2009 10:54:43 GMT by Adam
Apr 21, 2009 11:09:13 GMT
Oh I thought they'd been discontinued. Might be OK then.
Matt
Loxlee
Ford Capri with 1600cc's of pure power!........
Apr 21, 2009 11:37:45 GMT
a uniroyal rallye 340 and a semperit sport life are the tyres they do in that size, anybody ever used them? ive never heard of semperit
Apr 21, 2009 11:42:13 GMT
ive heard of em... sound like cheapo rubber to me
Apr 21, 2009 11:45:21 GMT
Semperit are continentals "cheap" brand, decent enough tbh.
Uniroyal are also supposed to be quite decent.
Apr 21, 2009 15:00:11 GMT
They are indeed 13" rims, sorry forgot to mention that. 185/60's seem to be about right I think. This will give only a 4% drop in rolling circumfurance from the 175/70 on there at the moment, and not risk taking anything away from the handling by adding too much width. Not going for the stretched look, purely because they sound a bit dangerous for proper driving, they are alright if you just want to cruise but funnily, I want to drive my car like it was designed for.
