froggy
Apr 15, 2009 19:12:05 GMT
bought this a couple of months back and it turned out to be a crock ,ive replaced the rear diff ,gearbox and engine and replaced the brake master cyl ,there is a spare diff and shafts which could be welded up for drifting ,the car has tein coilovers all round and good tyres and brakes , the engine is a serp 3.9 with the gear driven oil pump and cross bolting bosses in the block and has had a brand new water pump fitted plus it has a real steel trap door sump fitted, mild steel headers and twin stainless systems. the car is scruffy but would go back on the road without too much work. the car has left a bad taste in my mouth and I want rid no offers first with cash takes it. the car runs but needs a few final bits like the gear lever prop and shafts bolting back on .i have a oil pressure and water temp guage that have the senders fitted to the engine and have temp wired them to check oil pressure and water temp ,45psi at idle oil pressure. the car cost me £800 and ive easily sunk the same amount putting the thing right
Last Edit: Apr 22, 2009 5:42:12 GMT by Oldbus
Tefal
Apr 15, 2009 20:10:30 GMT
anymore pics of it? I shouldnt really but I wanna drift car lol
Apr 15, 2009 20:14:06 GMT
ive just bought a range rover or i would be kicking your door in ;D
97 volvo 940 turbo wagon 87 fiat strada abarth 78 gs1000 82 katana 1100 84 gsx1100 efe
froggy
Apr 15, 2009 20:18:26 GMT
il take some more pics tomorrow ,the engine picture is of the old engine . i should break it really as the engine and box will make the asking price as a complete donor package for a rod but as i said i want it gone
steve8
Apr 15, 2009 20:28:56 GMT
hi, how rusty is it underneath?, been bitten by a v8 one of these as well before, is it the rover 4 or 5 speed box?? is the prop cut to lenth?, heres hoping, steve
steve8
Apr 15, 2009 20:42:25 GMT
hi, go £400 now as its so bloody far away
froggy
Apr 15, 2009 20:48:44 GMT
its an lt77 5 speed the prop is right it was running and driving when i bought it but the box was nacked as was the diff and the engine which had curse word oil pressure ,i bought a diff from a turbo which has a torsen diff but the shafts were slightly different so i had to buy turbo shafts to go with the diff ,after pulling the old diff out it was the planet gears that were causing the diff to lock so they can be welded up for drifting, the master cylinder was leaking fluid so i bought a good used one along with a set of good used discs and calipers so there are spare brakes , the floors are good one side has been plated but done well ,there is a small hole in one of the outer sills but nothing major ,i run a garage /mot centre and when i changed the motor there was nothing serious body wise ,it might need a few brake pipes replacing but suspension wise it seems ok.
thats about it really first with the cash takes it
froggy
86 c reg
chunk
JD and coke please
Apr 21, 2009 23:54:33 GMT
I've just been asked to post this by a friend........
Please contact Dave Larkman at dlarkman@lotuscars.co.uk as I have a buyer waiting with cash and a trailer. We only have the trailer on Friday, so please get in touch. Thanks.
Cheers Rich
Bilateral leg amputee, ex pro drifter, ex 6ft tall, catastrophic idiot.
Hello mate this still up for sale or has it gone now??
Cheers Jon
steve8
hi steve here, is it up for grabs again? if so mail me back as we have a car to go up your way, cheers steve
