Mar 25, 2009 21:19:03 GMT
I think we are onto a good thing with the group help and learn welding idea, but we don't have a single place to put all the collected info - A wikipedia entry would be good (and we have a site wiki) if someone wants to take the plunge and write one we can go from there. Until then, here are the recent threads collected, and can we have this in "useful threads?" Learn to weld dayShield your eyes, I'm new to this welding businessAll filler - no pillar
IDY
Mar 25, 2009 23:34:46 GMT
In related metal working Jonny69 did a nice guide and demo of how to make repair panels in this thread with lots of nice pictures
I will get round to finishing it at some point
I went to see a mate of mine last weekend, we did some grinding on his 740T5 project to clean up some rusty spots here and there, we found a small hole in the bottom of the chassis rail and he went to borrow a friends welder and came back with a proper, professional MIG. The welds went on soooo much better than with my hobby MIG (Clarke 150te). We did some practice welds to set it up how we wanted it and I couldn't believe how much easier it was to get a decent, solid bead. The wire feed was super smooth (unlike my Clarke that kind of pulses the wire out) and there was loads of shield gas coming out)
I guess its no surprise when you look at the price difference between the two machines.
Though I did have a problem when welding upside down (first time I've tried it) When the wire hit the metal and melted, it just kind of fell off in a ball and most often, went down into the shroud. Is that normal? Is there any way round this apart from turning the car over?
There are a couple of awkward patches to do in the floors in the area of the forward jacking points and outriggers. Is it best to weld these from inside the car?
PS, good idea on the How to weld thread.
Last Edit: Mar 26, 2009 8:03:06 GMT by suterman
Ta for the link to johnnys thread, I would have included that if I'd seen it Welding upside down is hard! As you noticed, the weld pool falls off into the torch a lot, so try less current (turn welder down) or much shorter bursts so it gets a chance to cool and solidify before it gets heavy enough to drip. Floor sections are easier to do from inside, but make sure the outside is free of underseal and dirt first, and seam sealer the outside of the repair after you finish or the repair becomes a new rot trap.
No wire feed probs like that on my 151TE, its smooth enough for rock 'n roll. Might be a minor prob like rusty wire? Clogged liner, manky swan neck etc. Mine was giving a bit much of the brown dust recently, chucked in new liners, swan neck etc and all is good and beads neater too. No doubt it's never gonna be as good as posh kit, but it's good enough for for DIY tomfoolery.
When I'm welding upside down, I go for a higher wire speed and lower current. This makes it slightly easier, but you need to be carefull you still get penetration - its a fine line to balance and all too easy to get welds that sit on the surface without going deep.
I still get metal dripping into the shroud though, but I prefer it goes in there than up my sleeve.
spiny
Wiki Admin
I am abivalent towards car electrics ...
Club RR Member Number: 167
Learn how to weld threadsspiny
@spiny
Club Retro Rides Member 167
Mar 26, 2009 10:55:10 GMT
(unlike my Clarke that kind of pulses the wire out) My spare welder (sip migmate something or other) did this, so I replaced the liner with one from machine mart - works a treat now - smooth as you like. The liner was about seven pounds I think, and although is for a different welder, is easy to adapt. I have pics somewhere of how I did it - I guess this thread would be a good place to add them ?
Mar 26, 2009 11:03:28 GMT
The whole 'weld dripping into the shroud when upside down' thing.
Are you guys not holding the torch at a 45 degree (ish) angle to the work then?
I was always taught to hold the torch at an angle and weld into the gas pool.
Doing it that way the weld shouldnt be able to fall into the shroud.
Mar 26, 2009 11:05:09 GMT
I've got plenty more to do on that Zodiac so keep an eye on that thread. I'll be working upside down, outside, limited access, Clarke 150 MIG on a 50m extension lead and disposable CO2 bottles so you can see how it's done
spiny
Wiki Admin
@spiny
Mar 26, 2009 11:22:29 GMT
Mar 26, 2009 13:01:25 GMT
Good pics there. The Clarke's a bit less hassle to change the liner - but loosen the cover forward of the wire feed roller (4 screws) don't attempt to remove it - there's nuts on 2 of the bolts ... these let you know they exist by the little "plink" sound from the 'hidden' compartment. For which you have to remove handle, remove cover screws and rotate back the whole cover. Swan neck replacement's well worth doing, and it has a small liner of it's own. I bought a kit from Wilstar, which has the lot in plus shrouds and nozzles.
Mar 26, 2009 13:39:30 GMT
Wow, those SIPs really are quite curse word inside aren't they. No wonder the feed goes wrong on them, the angles and tensioner are appalling.
Mar 26, 2009 13:45:18 GMT
I think this would make a great Wiki entry SOC .. good idea... I need to fix the wiki, having broken it somehow! ... Thanks for all the knowledge share folks.
spiny
Wiki Admin
@spiny
Mar 26, 2009 13:57:41 GMT
Wow, those SIPs really are quite curse word inside aren't they. No wonder the feed goes wrong on them, the angles and tensioner are appalling. yup, the tensioner is awful - i've added a much longer bolt to mine, as the springy metal bit has lost most of it's 'spring' and wasn't putting down enough pressure for the wire to feed through.
Mar 26, 2009 15:43:11 GMT
Wow, those SIPs really are quite curse word inside aren't they. No wonder the feed goes wrong on them, the angles and tensioner are appalling. yup, the tensioner is awful - i've added a much longer bolt to mine, as the springy metal bit has lost most of it's 'spring' and wasn't putting down enough pressure for the wire to feed through. Be sure to release the tensioner each time you put the welder away. I never used to and ended up with a non-springy spring and eventually twisted the whole mounting to hell.
Mar 26, 2009 17:09:55 GMT
hmmm, thanks for the tips, I will try putting a new liner, I recently replaced the swan neck, (I think this is the third one) the bloody thing kept coming out of the trigger/handle thing until I glued it in place and a new one improved results a lot...
I was thinking that the drive wheel spindle or motor mounts went bent/loose???
Learn how to weld threadsChasR
@chasr
Club Retro Rides Member 170
Mar 26, 2009 19:52:09 GMT
I have a SIP MIGmate with a new liner. From before it's much improved! If you can, go for a steel liner which has less resistance, and that can unleash a new breath of life into a tired welder.
One thing. Do you guys overlap, or weld in like for like with the panel meeting up spot on, hence appearing as if it was never welded before?
Last Edit: Mar 26, 2009 19:52:51 GMT by ChasR
Mar 26, 2009 19:52:56 GMT
Mar 26, 2009 20:04:18 GMT
One thing. Do you guys overlap, or weld in like for like with the panel meeting up spot on, hence appearing as if it was never welded before? A bit of both, it depends on the circumstances. Butt welding (no overlap) is a right pain but necessary at times, overlap is easier but messier (and creates a double skin perfect for the rot to set back into if you arnt careful) Quite a lot of the repair work I see involves tearing off a rusted out patch and doing it again properly.
Mar 26, 2009 20:26:11 GMT
i always tend to but weld if possible, but its alot easier on thick pre 1960's panels!
