spiny
Wiki Admin
I am abivalent towards car electrics ...
Club RR Member Number: 167
Mar 25, 2009 22:02:45 GMT
the one i'm currently enjoying: the cause on my anguish and the reason for this thread: more reference material: I'm sure I used to have more, but must have lent them out and not got them back ...
spiny
Wiki Admin
Mar 26, 2009 23:34:34 GMT
Last Edit: Mar 26, 2009 23:34:59 GMT by spiny
spiny
Wiki Admin
found some time earlier to do a bit more, cleaned up the front plate and fitted it with a new gasket after very carefully removing the timing gear. I need to swap the lot over as the Marina engine uses a single chain and tensioner with a bigger timing cover, whereas the front plate I need to fit the Midget uses the duples chain with the smaller cover. I now have all the bits needed to do this
spiny
Wiki Admin
apologies if this is turning into a readers rides thread, but I'm pleased that I'm getting somewhere of course, as soon as I start the engine (assuming it does) oil will probably spurt out everywhere new chain and small sprocket fitted up with original big sprocket: all back together: need to check the locking tabs on the flywheel, and then a trial 'fire up' is on the cards
