chunkybond
http://www.maxmarcusevents.co.uk
Right,
Ive taken the badges off the back of my volvo 340, and its left a whole load of glue residue, and looks messier than with the badges on! not the look i was aiming for..
any help would be greatly appreciated!
When i took mine off i used some thinners on a cloth and wiped it off.Could also try lighter fluid,petrol,nail varnish remover.Just put some on a cloth/rag a wipe over gently.Don't use to much in one go as could damage the paint work.
I used thinners for this also - go easy tho......as it works very well as a paint remover also !
I was going to say lighter fluid as i don't think it damages the paint and it's what viynal sign writers use.
OAP drifta Volvo 340,Williams power 1960 Beetle twin 40's 1776cc
Isopropyl Alcohol and a lot of elbow grease should do it followed by a bit of T-cut to blend it all in
i used a heat gun and scraped it off,
if you're gonna do it wrong, you might as well do it wrong properly
Gud välsigna det röda blocket
nissan cube - jdm toy
volvo 940 turbo - 22psi
FOR SALE 2002 NISSAN CUBE
When I stripped the trim off my 240 I used a thing called a toffee wheel, it goes in a drill and rubs off the glue with ease, it would have taken me days to clean it all off with my fingers. (meters of it) it ended up taking about 30 minutes, I was amazed.
Tim
There is some stuff you can buy called 'sticky stuff remover' (i kid not) might be a betterware type product - i've used it to clean sticker residue off of interior/glass and its excellent citrus based degreaser works well too! edit... this is it www.desolvit.co.uk/pages/sticky_stuff_remover.htm
Last Edit: Mar 8, 2009 16:21:42 GMT by Tim
When I stripped the trim off my 240 I used a thing called a toffee wheel, it goes in a drill and rubs off the glue with ease, it would have taken me days to clean it all off with my fingers. (meters of it) it ended up taking about 30 minutes, I was amazed. Agree'd, get a toffee wheel. They are amazing and do no damage.
Petrol on a rag, scrub. Jobs a goodun!
v8ian
Probably find brake cleaner will take it off, WD40 left overnight sometimes softens glue as well.
Panel wipe should remove it with no damage to the paint.
Tim
that should do it
awoo
Lynx or any other deodorant aerosol will take it straight off, spray on real close, wipe of - but you need to be quick cause it evaporates in a few seconds and you have to spray it on again. i use it all the time for cleaning guitars that have had duct tape on them. leaves no marks or anything and its real quick.
So called, becuase they smell like toffee when they get hot.
