Fuzzy
Powered by bees.
I've started thinking about options for another car and the more I think about it the more a 205 XS seems to make sense. Apparently they handle well and have a decent amount of grunt, but has anyone on here owned one? They are elusive beasts. Please share stories of thumping down B-roads, things to look out for, or indeed cars of similar fun factor/insurance cost/retroness I may be overlooking. Thanks amigos. Have a couple of pics. Edit: Oh yeah, I'm ringing after one tomorrow which is 30 miles away and will be having a gander if it's not sold yet.
Last Edit: Jan 29, 2009 1:07:00 GMT by Fuzzy
piperfish
Dinky-di 100% meat and veggies
Hi dude The Pug XS is a good little car still plenty about...don't overlook a basic 1100 model. I used to have a 60 horse 1100 pug it was a right nail. but in first and second it would beat anything. They handle aswell, you can throw one into a bend an it will lift the inside rear wheel easily. Watch out for worn inner track control bushes as they can lead to entertaining handling.
Its my snake...I trained it...and I'm gonna eat it....
rysz
I have owned 2 XS's and they are the best cars that I have ever owned! They have a twin choke carb and when the second choke comes on song at about 3000 rpm, it is like a turbo kicking in ;D The 5 speed box is really short and they are amazing b road blasters - tend to be a little thirsty on motorways as the box does not have long legs so the second choke is always on song. I would have one in a flash again and can't recommend them enough! More fun than a sackful of nubile, open minded and willing young ladies with a bottle of baby oil! (Sort of ;D) If it is even half good, then BUY IT (and give it to me!)! Rysz.
simes
Early ones have the XY engine - you need to go for the later TU 1360cc engine shared with the AX GT - F reg onwards. The twin choke carb is amusing. Lightweight and economical. They can give a 1.6GTI a run for its money.
Simes
205Mi16 - 262 cams, Jenvey Throttle Bodies, Emerald managment blah blah...... E91 320D MSport Honda NC30 Vespa 300GTS
mym
Jan 29, 2009 10:13:22 GMT
90 bhp, not far off as fast as a 1.6 gti i'd love one when i can find some spare cash!
Jan 29, 2009 10:20:06 GMT
I loved mine so much i decided to turn it in to a full on trackcar ;D Used to be great on the b-roads when it was completly standard because no-one expected it to go well or handle good.
If you do buy one drop me a PM as i have some bits that you might be interested in to give it a bit more poke
Jan 29, 2009 10:25:19 GMT
Yup, cracking motors, upset many cars with one who just don't expect them to go as well as they do. Handle well but comfortable, beleive the later TU engine is better-that's what mine had & it was ace! Tried it on 14" gti wheels & spoilt the handling, so put it back on standard steels-much better.
Fuzzy
Powered by bees.
Jan 29, 2009 11:00:33 GMT
Thanks guys. He's got it and has been singing its praises this morning, I'm going to view on Saturday morning. It's 1989 F reg - will it have the TU engine then?
Twin choke carb sounds like fun, can't wait to see what it's like.
*Gets insurance quote*
Jan 29, 2009 11:10:10 GMT
I have a 205 Roland Garros (XS in party frock) and owned an XS which i broke for spares as it was fairly rotten. I also have an AX GT which is the same idea in a different shell with a slightly higher spec. The TU3S engine is a lovely one, twin choke carb and cammy enough to be fun without being annoying. Close ratio box means they shift upto legal speeds but drink a lot if you like to sit at 80mph (which is 4500rpm in 5th and into the 2nd choke on and off). Very economical when you take it easy. Should you wish to modify then GTi parts and common and good upgrades.
filmidget
East Midlands
Mostly Lurking
Jan 29, 2009 12:49:10 GMT
I have an 1400 XR, and even that's entertaining.
More power, c/r 'box and slightly stiffer suspension must be a lot of fun.
'79 MG Midget 1500 - Still patiently awaiting attention '02 Vauxhall Astra 1.8 Elegance(!) - Better than you might think '03 Mazda MX5 - All new and shiny looking (thanks to Antony at Rust Republic) '09 Renault Clio - Needs to go.
Jan 29, 2009 12:50:12 GMT
I have an 1400 XR, and even that's entertaining. More power, c/r 'box and slightly stiffer suspension must be a lot of fun. Oh you're missing out! ;D
205gti
Jan 29, 2009 14:00:13 GMT
I own a 1.1 trio S and the 1.6 GTi. I am sorry to disagree with Piperfish, but the 1.1 is hideously slow. It might be rose tinted memories from back when traffic was a bit slower on your part, but my 1.1 really struggles, especially with hills. Also the suspension is extremely wallowy for such a light car. The steering and gearchange remain quite satisfying, but that's about it. Its not even particularly economical.
The 1.6 on the other hand is an absolute riot. It might only be a little faster than the XS, but its got a firmer still suspension, thicker anti roll bars, more equipment, injection and a short ratio 'box. As a result, 0-60 is almost on a par with the 1.9, but the engine is a lot happier to rev.
A well set up, i.e. decent rear beam, 1.6 is an absoulute joy on British B Roads. There are always thousands of parts on e-bay and lots of enthusiasts.
The 1.4 XS is very much in the same vein as the 1.6 GTi, slightly less focused, a bit lighter and slightly softer. It revs hungrily if you get the later model.
An interesting aside is although many of the GTi parts, such as the braking system, suspension, air filter, exhaust etc are incompatible with the GTi models, most of the Rallye bits will bolt straight on. So you could have the rallye suspension setup for quite cheap and there will be rally bits and bobs that you can bolt on.
Hope that I have got most of that factually correct!
Oh and I should mention the 205gtidrivers forum which has a section for the TU engine and a good few XS drivers. Plus more info than you can shake a stick at, buyers guides, people with amazing cars and thankfully very very few boy racer types.
sex and pugs and rock and roll
205gti
Jan 29, 2009 14:04:18 GMT
Jan 29, 2009 14:10:10 GMT
I would definitely not describe my 1.1 205 as 'hideously slow'. As long as you are prepared to keep the engine revs up, so it's in its 'sweet spot', it'll keep up with most things on B roads. Addmittedly, it's not great going up hills, but as far as smiles per mile are concerned, it's great!
As for economy, my other half commutes 70 miles a day in it, and it averages about 45-50mpg, which is pretty damn good.
Finally - what's wrong with wallowy suspension? Give me a comfortable wallowy car over a modern with back breaking 'sports supension' any day!
Last Edit: Jan 29, 2009 14:13:59 GMT by Rhodrich
1951 Split Window Beetle - SOLD! 1965 Mercedes 230SL 1966 VW Beetle 1968 Mercedes 280SE
1972 VW 412LE Variant - SOLD! err.... 2004 Toyota Corolla
Nathan
Club RR Member Number: 1
Tell Me About: The Peugeot 205 XS.Nathan
@bgtmidget7476
Club Retro Rides Member 1
Jan 29, 2009 14:16:20 GMT
I've started thinking about options for another car and the more I think about it the more a 205 XS seems to make sense. Apparently they handle well and have a decent amount of grunt, but has anyone on here owned one? They are elusive beasts. Please share stories of thumping down B-roads, things to look out for, or indeed cars of similar fun factor/insurance cost/retroness I may be overlooking. Thanks amigos. Have a couple of pics. Edit: Oh yeah, I'm ringing after one tomorrow which is 30 miles away and will be having a gander if it's not sold yet. If that ones no good I am selling one bud! This one infact, ahh and @ £250 its cheap as
Last Edit: Jan 29, 2009 14:20:48 GMT by Nathan
Jan 29, 2009 14:18:50 GMT
An interesting aside is although many of the GTi parts, such as the braking system, suspension, air filter, exhaust etc are incompatible with the GTi models, most of the Rallye bits will bolt straight on. So you could have the rallye suspension setup for quite cheap and there will be rally bits and bobs that you can bolt on. I think you'll find that most of the parts are actually interchangeable between the XS and GTi, only the engine parts aren't (obviously.... different engine). The Rallye available in britain was a softer car than the XS, with a 75bhp single choke carb, thinner torsion bars etc. so you won't find any upgrades from them! The Euro rallye actually used a variety of parts from the GTi and XS, no new parts AFAIK. Mr Swordfish runs full GTi suspension (including subframe) and brakes IIRC. I'm running GTi torsion bars and GTi front brake. The only real design differences are the subframe (different gear linkage and TCAs/ARB instead of wishbones) and the engine/box!
Fuzzy
Powered by bees.
Jan 29, 2009 14:27:30 GMT
I've learnt a lot today! I do hope it has the TU3S engine, the car sounds more or less spot on for my needs right now - pointy enough for fun, supple enough not to destroy my back on Yorkshire's rougher roads. I doubt I'll get much sleep on Friday night. Will bring pics on Saturday.
mym
Jan 29, 2009 15:11:29 GMT
if you think the 1.1 was slow, you wanted to try my 950cc xe model!! that defined slow, i managed (once) to see 100mph out of it and that was on a steep downhill dual carriageway on the way to chester!! thought bust alternators, driveshafts, CV joints, CV boots, exhausts and knackered valve seals i loved the thing
Jan 29, 2009 17:18:02 GMT
100 mph! That's fast!
My Imp will only do 80 on the flat, 85 on a downhill stretch.
I drove a 205 XS on an autotest with Bristol Uni motor club - enormous fun. I'd have one in a flash if I needed a more modern car.
James
Jan 29, 2009 17:30:34 GMT
An interesting aside is although many of the GTi parts, such as the braking system, suspension, air filter, exhaust etc are incompatible with the GTi models, most of the Rallye bits will bolt straight on. So you could have the rallye suspension setup for quite cheap and there will be rally bits and bobs that you can bolt on. I think you'll find that most of the parts are actually interchangeable between the XS and GTi, only the engine parts aren't (obviously.... different engine). The Rallye available in britain was a softer car than the XS, with a 75bhp single choke carb, thinner torsion bars etc. so you won't find any upgrades from them! The Euro rallye actually used a variety of parts from the GTi and XS, no new parts AFAIK. Mr Swordfish runs full GTi suspension (including subframe) and brakes IIRC. I'm running GTi torsion bars and GTi front brake. The only real design differences are the subframe (different gear linkage and TCAs/ARB instead of wishbones) and the engine/box! Yeah i am running full GTI suspension on mine. Front: 1.9 GTI subframe, 1.9 GTI Bilstein OE spec dampers, Eibach -40mm lowering springs, 1.9 GTI ARB (tried a 309 one and subsequently no ARB but i found the standard one to be the best) 309 GTI wishbones, standard driveshafts, 1.6 GTI calipers, 1.9 GTI discs Rear: 1.9 GTI beam and brakes, standard torsion bars and ARB. And all of that, save the gearpost on the subframe, just bolted straight on. Yours will be the TU engine being that year.
