the spring on the left is standard ride height, the one on the right is 3 inches lower. changed the front passenger side this afternoon and its still sitting as high as it did. bounced on it for a while and took it for a spin, over 6 speedbumps and round some right hand corners in the hope it would settle its self. it hasnt, anyone got any ideas why its not gone low? will it sort its self out when both are done? cheers
Get all of 'em on, takes a few hundred miles if not more to settle afaik, try it and see!
If you have one shorter spring the other 3 will probably hold the car level.
theres only one standard spring on it now, the front drivers side. the backs down about 2 inches, front passenger side has a 3 inch lowering.
Are the new ones much firmer than the old? ie. they don't compress so much.
Peugeot 307sw - Suzuki SV650S - MX5.
the lowering stick wasnt big enuff
they do need to bed in
2001 HONDA CT110 (NOT RCV)
with the weight of the car sitting on it, it doesnt look like they compress as much. but id have thought with them being physicaly shorter that this would translate to an equivalent drop on the car.
check the poundage - shorter ones usually are higher - if more than the stock ones then you wont get the drop you want
why isnt my car lower?BenzBoy
@benzboy
Club Retro Rides Member 7
I think with the other side being standard height it'd have an effect. When I chopped my coils it went a bit lower and I was a bit disappointed. Then I drove it for a bit and it went lower still. Then I drove it all week and it went even lower.... then I was starting to brick it as I didn't have much arch clearance left! ;D
Jarvis
I WISH
lets just hope the back dosent keep on dropping as it beds in there isnt that much clearance now!!
fingers crossed the front drops abit cos if not they will have to come back out and get chopped
Get inside the car and take a deep breath. Then get out and call your bank manager, asking to borrow about £2m (for a magic golden goat or something). If he says something like 'Is this a fugging wind-up or summert you tw*t?' it will be because you are talking like daffy duck - classic sign of a car over-filled with Helium (of which high ground clearance is also a symptom). If this is the problem, simply use a vaccuum cleaner to get rid if all the Helium, and the ride height should correct itself automatically.
If its not that, i don't know i'm afraid.
Last Edit: Aug 1, 2005 16:39:43 GMT by Mr_Bo11ox
@benzboy
Get inside the car and take a deep breath. Then get out and call your bank manager, asking to borrow about £2m (for a magic golden goat or something). If he says something like 'Is this a fugging wind-up or summert you tw*t?' it will be because you are talking like daffy duck - classic sign of a car over-filled with Helium (of which high ground clearance is also a symptom). If this is the problem, simply use a vaccuum cleaner to get rid if all the Helium, and the ride height should correct itself automatically. If its not that, i don't know i'm afraid. I was going to suggest that, but I thought that they would have tried the obvious stuff like the old helium trapped in the vehicle, as well as measuring the gravitational field to see if variations in the Co. Durham area would affect such issues. But seeing as you're stating obvious solutions MrB...
have you got adjustable spring seats ? if so the length of spring doesn't really determine the ride height its where the spring seats are sat. So if you had the springs on the left and then wound the seats up to meet the spring with no load on it you would end up with the exact same ride height as if you did the same with the spring on the right (assuming the spring weights are the same)
You have to be carefull changing to shorter springs as you can break things really quickly if the coils bind before you are on the bump stops.
it's not fancy self-levelling suspension is it? it might be confused.
GavinJ
MGB 3.9 v8 Sebring
Club RR Member Number: 209
why isnt my car lower?GavinJ
@gavinj
Club Retro Rides Member 209
I changed the springs recently on my mg and it didn't appear any lower at first either, but after using it for a few days they soon settled.
Just give them a a bit of time
Shortcut
I won't be there when you cross the road, so always use the Green Cross Code.
You need to eat a few more pies mate. I get a 2" drop everytime I get into the ZS, plus I get to scoff loads of lovely pies!!
This space available to rent. Reach literally dozens of people. Cheap rates!
You need to eat a few more pies mate. I get a 2" drop everytime I get into the ZS, plus I get to scoff loads of lovely pies!! Doesnt the power to weight ratio half though?
YO TONYCC! just' watchin some crime sheeet on telly - guess what sort of motor the bad-boy-gangsta-drug-dealin'-pimp types are ho-ing about in......
YO TONYCC! just' watchin some crime sheeet on telly - guess what sort of motor the bad-boy-gangsta-drug-dealin'-pimp types are ho-ing about in...... lada samaras? ;D ;D ;D ;D going to do the remaining side tomorrow, then drive it about for a couple of days to see what happens. like jarvis has already said, i hope the back doesnt settle too much, cos its a bit lower than intended, it being my daily driver and workmobile. looks cool as a mo'f*cker though ;D
Jarvis
I WISH
looks cool as a mo'f*cker though ;D i have to agree with that always like to see sparks from end trailing the floor ;D ;D ;D ;D
@benzboy
Yeah once it's all slammed and levelled out you'll be gingerly crawlin' over speed humps in no time mate!
