Dec 28, 2008 15:38:49 GMT
They're HIF44s, aren't they? 1 3/4? It looks like you can take a standard HIF44 and rebuild it with a 'turbo' kit and end up with the same thing, according to some of the forums I've read - is this the case? Does this mean I could fit twin HIF44s to my Sprint, replacing the HS6s, then at a later date force feed them whilst in the meantime running them NA? Just wondering........Eatons are floating around again...seems like a good idea.... It's an 'on the cheap' job, hence the carbs - plus I like the idea of mucking about with them. I don't mind the draw through (like a single HS8 or similar) to feed it but it's the potential lack of workable intercooling that troubles me in that instance!
Last Edit: Dec 28, 2008 15:41:03 GMT by Lewis
Dec 28, 2008 16:36:30 GMT
You can rebuild a normal HIFF44 to use with a turbo. There is a thread on here detailing it www.turbominis.co.ukI will see if I can find it for you.
Dec 28, 2008 16:40:33 GMT
yes there 1 3/4 hif44 s to turbo ify (if thats a word) a hif44 you block the vent to atmosphere tube on the left of the fuel inlet have a look on turbo minis .com theres loads of info on there how to blow throu carbs andy
Dec 28, 2008 16:40:47 GMT
Thanks, I found several threads there about HIF44 non-turbo to turbo rebuilds! Least I know it's a viable route if I do see some cheap non-turbo HIFs, although I'll keep an eye out for the already sealed and set turbo ones
Dec 28, 2008 16:43:41 GMT
Dec 28, 2008 19:55:00 GMT
if you go the eaton 45 route you need to remember that they are "dry" as standard. in that you need to "blow" through the carb.
I had a "wet" setup, in that the carb is still suck through into the charger then to the engine. not sure its a great idea as you end up with a massive run from the carb to the charger and idle was wibblepoo.
so if you want a wet setup you need to get the eaton rebuilt with different seals.
slater
Club RR Member Number: 78
Dec 28, 2008 20:39:42 GMT
hence why hes asking this question surely!! :/
Dec 28, 2008 22:32:40 GMT
Yea, I'd be blowing through the carbs, so the charger would be dry. I'm aware of the potential issues surrounding it but like I say, it'd be the intercooling (or lack of it) issues with a draw-through setup that put me off most of all Not to say you can't intercool a draw through setup but there's enough compromises being made as is! I found an HIF44 for sale and another Sprint manifold so will put the two together and see if it sits OK. Then at least I can start looking at how the rest of it would fit together in the engine bay
spacekadett
F*cking take that Hans Brrix!!
Dec 28, 2008 23:00:54 GMT
I think you could mod the carbs you have to run turbo'd. IIRC PPC did this on their turbo roller, as a HIF44 would've been a bit small for a V8
Mechanic's rule #1... If the car works, anything left on the floor after you finished wasn't needed in the first place
Dec 28, 2008 23:03:46 GMT
Haha, swimming hole through a straw springs to mind! I remember that too now that you mention it - something about tapping and feeding the dashpot with boost to equalise both sides of it. I shall dig it out!
