Anybody got any?
Trying to bleed the brakes on my vespa (ok not a car but its a model most scooter boys know nothing about so I've come here for help). Both brakes are hydraulic from the same master cylinder which has 2 outlets. I've tried bleeding both wheel cylinders in turn but on the first push of the pedal it is very soft. On the third it is rock hard and the brakes work well. There are no leaks and the fluid level has not altered.
I've been using a one man brake bleeding kit (one way valve type).
Any tips or what am I doing wrong!
