Jul 21, 2005 17:31:27 GMT
basically i went out to the metro this morning and no the key will not turn in the ignition! eeek! i need the car for monday morning and cannot get anywhere for parts! i was just wondering if anything simialr has happened to you and what i can do to make it work!its been fine but now its kuput! robin
if it aint mini then it aint a mini.
том
"If in doubt, flat out!"
Jul 21, 2005 17:34:37 GMT
WD-40, the answer to all mechanical problems
1988 V8 Rangey Bobtail :: 1968 Volvo Amazon 133 Ratrod :: 1977 Land Rover 88 :: 1985 Opel Monza GSE :: 1983 MKII Fiesta
Jul 21, 2005 17:45:52 GMT
Another old remedy is rub the nib of a pencil along the edges of the key the graphite or whatever it is these days lubricates the tumblers allegedly
Jul 21, 2005 17:52:28 GMT
Either of those two might well do the trick. Other than lubricating the barrel of the ignition lock to hell, or removing the wires from the lock and attatching them to a switch to allow you to start the car (extreme I know, but at least it'll get you moving, although if the car has any security systems like immobilisers they may well kick up merry f*ck at that.) until you can get the lock moving again or get a new one from a locksmith if it really won't budge, I'm not sure what else would work. With any luck lubricating it should work, try squirting WD40 or similar into the barrel of the lock using the little straw thing you get with the tins of it, and maybe soaking the key in it too, and see if that eases it up.
"He's not the messiah, he's a very naughty boy!"
Jul 21, 2005 17:55:04 GMT
Give it a good kicking! Failing that a good wrestle on the steering wheel with the key in and lashings of wood-40 oughta shift it.
Jul 21, 2005 18:47:57 GMT
You tried the spare key (if you have one). If your key looks worn see about getting a new key made. If the barrels worn you might be better of getting a second hand barrel (or lock set) from a scrapyard and fitting that. It will save a bit of heartache later on.
том
Jul 21, 2005 18:50:32 GMT
phoenix, what do you do, you know everything about every single car ever made, it's very usefull, but a little bit scary
Jul 21, 2005 18:55:53 GMT
cheers for the help lads, after my rage calmed down abit i went back out, wd-40'd the mutha fooka and retraced my steps back through.
when i got the car the ignition barrel moves slightly on the colum, so in my search for [recision i ripped off the cowling and proceeded to tighten the bolts holding it on. brilliant i thought, job done!
so i basically undid the bolts and returned the bolts to there "loose" status and bobs ure uncle!
i did try all the afore mentioned methods thought, hitting it with mole grips, spanners,my hands, adjustable wrench! now i can go to bed with my safely alarmd and steering locked car outside, ahhhhhh!
cheers again! robin
i need helpDarrenW
@darrenw
Club Retro Rides Member 74
Jul 21, 2005 19:06:33 GMT
The key on my Golf is the original one, and it's worn smooth over the years. So from time to time I have to spend up to ten minutes jiggling it around in the ignition barrel, trying to get teh steering lock off... It's very frustrating! There's a spare, but that's a copy of the main one and therefore new, but equally smooth...
Must get round to getting a new one cut from the number!
Jul 21, 2005 19:19:35 GMT
i got a new key cut today as its virtually wafer thin in the middle as it has to run over a ball bearing to get into the barrel and its worn the middle out!
the new key is still a bit burred up and stiff but I'm going to smooth it a little tomorrow with wet and dry as its stiff in the doors and the tailgate
robin
Jul 21, 2005 20:18:35 GMT
phoenix, what do you do, you know everything about every single car ever made, it's very usefull, but a little bit scary Its also mostly bo11ox ;D
Davenger
It's only metal
Club RR Member Number: 140
i need helpDavenger
@dminifreak
Club Retro Rides Member 140
Jul 21, 2005 20:22:09 GMT
Ah, but the art comes in knowing where to apply said bo11ox ;D
том
Jul 21, 2005 20:31:42 GMT
ahhh, it all becomes clear
Jul 21, 2005 20:52:03 GMT
Confuscious say: 'Knowledge is merely the correct application of talking BolĀlocks.'
*n
metro's should have a box attached to the end of the ignition barrel, take this off, and anything will work in it to get it started, you just have to get round the steering lock (snapping it does the job ;D )
ps, i know this cos i worked at a scrapyard, not cos i was an unscrupulous curse word ;D
oh, lol, if you got it sorted, then forget what i last said ;D
Jul 22, 2005 14:42:46 GMT
don't wet and dry your key, itll change the cut. trust me i cut keys for a living!!
"quote hairnet"
I'm not paying nine pound for a pi$$!
[/quote]
metro's should have a box attached to the end of the ignition barrel, take this off, and anything will work in it to get it started, you just have to get round the steering lock (snapping it does the job ;D ) ps, i know this cos i worked at a scrapyard, not cos i was an unscrupulous curse word ;D Surely if you worked in a scrapyard that means you are an unscrupulous curse word ;D
