Dec 13, 2008 10:41:32 GMT
Hi as title. I'm in the process of fitting a 1.8 Nissan Slivia turbo engine (single over head cam version S12) in my Anglia estate ... problem is it's an auto as such I need the manual flywheel. I have gearbox etc. I'm also in need of a clutch slave cylinder although not as important. I'm based in West Yorkshire but can arrange courier if your happy to box up etc.. Thanks for looking
Last Edit: Mar 2, 2009 6:22:54 GMT by Oldbus
beany
Hmmmmm
Dec 13, 2008 17:18:51 GMT
Maximum signature image height = 80 pixels
Dec 13, 2008 17:50:50 GMT
have you got the plate thing that goes behind the flywheel too? check it has a spigot bush also.
Probably got a slave cyl somewhere if you get stuck
Dec 13, 2008 19:46:31 GMT
Yes tried there first - very helpful and sorted me with most of the bits I need. have you got the plate thing that goes behind the flywheel too? check it has a spigot bush also. Probably got a slave cyl somewhere if you get stuck The engine I have is out of an auto so i'm unsure exactly what i'll need. I have the clutch and gearbox. this is the picture of the engine 'as is' If you have a slave cylinder, cheers let me know
Thought i'd bump this thread up - I'm still after the above parts if anyone can help. I thought i'd sourced em via Nissan Silvia site but the chap never got back in touch with me having gone through what I have I also need a starter, Crankshaft pulley, Cambelt cover complete and a manual Transmisson ECU. I would consider buying a whole car - crashed / smashed/ rotten etc but must be manual transmission and can collect within say 100 miles of Wakefield West Yorkshire. Or does anyone know of one in a scrap yard in my area Any help greatly received as i'm nearly at the position to get this lot trial fitted..
