Selling due to buying another runabout & no room to store.
108k miles, Mot until Jan 17th 09, tax end of Jan 09. Should pass another mot with minimum/no cost.
Bodywork in fair condition, some parking dings & scratches, clean for year. Needs a good wash in the pics but haven't had time, ill do it before it goes.
All tyres have decent tread, even the spare.
Excellent starter, whether hot or cold. Doesn't smoke or overheat. Everything works as it should.
Will return 500+ miles on a tank of diesel all day, every day. Super cheap to run.
I replaced the engine for a good used lump as the original span a shell at 80k. I replaced clutch, driveshafts & full exhaust at the time of swap.
This year i have changed the radiator, heater matrix, drivers side wheel bearing, heater blower, rear engine mount & timing belt was done at 100k. The oil & filters have been changed regularly. Massive pile of receipts for parts. Fully undersealed.
Bad points -
Mk1 tailgate due to back window smashing last year, fits ok though after trimming.
Cracked rear bumper on passenger side, done by previous owner.
Minor oil leak, possibly sump seal. Not bad enough to worry about though, never uses any oil between changes.
Minor wear on drivers seat, interior in clean condition apart from that.
Asking for £150 ono, this will make a good cheap runabout for somebody. No timewasters please. First come first served.
Bad points -
