stuey
ram thruster 4000
Nov 15, 2008 13:55:47 GMT
My 318I is slowly destroying its cooling system and it looks like its the turn of the water pump to start failing- whilst I am mechanically proficiant enough and fairly well tooled up to to the job I need to know if theres any special tools I need to do it as I having a sneaking suspcion theres a viscous coupling hiding in there somewhere and cos the fiat earnt its self a trip home on a low loader last night once its apart I'm stuck. so if any one can provide an idea of what to expect (or point me to a web guide on changing it) then I would appreciate it. heres a shiny bmw race car in thanks-
Last Edit: Nov 19, 2008 14:35:19 GMT by stuey
1987 fiat 126-nearly actually done! 1972 beetle - lawn art 2003 z4 daily-new wheels a comin! 2008 R56 Mini cooper "mental Mickey"
Nov 15, 2008 15:02:38 GMT
for most bmw's all you need is a 36mm spanner, slip it onto the coupling and curse word it with your fav hitting stick - remember its reverse thread you may need a couple of longish 6mm bolts to screw into the old pump, wind em in evenly to pull the pump out, as said, this covers most i have done but i don't recall doing a 318 so it could be all plums regards that engine dig in matey
fordghiarsxrboy
old fords don't die... i buy them!!
Nov 15, 2008 18:19:05 GMT
what year is it on mate. my sisters was a piece of pssi. the water pump has a plastic impeller in side the block which breaks off causing it to act like a head gasket prob. i don't recall the viscous being in the way .the belt is on a tensioner and the water pump pulley is plastic which some times breaks up. any probs give me a shout mate.
one retro ride is never enough 2001 transit 2.4 red 1989 escort ghia 2.0 16v bike carb'd 1989 escort estate 1.4 gl 2008 vauxsnail zafira sri (wife's choice)
xtrmjks
Boost Junkie!
Nov 15, 2008 18:26:44 GMT
36mm spanner and some "clank" to get viscous off, You can get water pumps with metal impellor, plastic water pump pulleys are rocking hor......even from BMW! and swap to electric fan..
Nov 15, 2008 20:03:37 GMT
errr, 36mm is a ford and vaux. bm's have always been 32mm left hand thread stu- you have my number, give me a call! I'll be happy to help mate
Nov 15, 2008 21:20:39 GMT
It is a 32mm! And it is a left hand thread!
And if your car has a plastic thermostat housing try not to smash it up with the spanner when undoing the fan as they are hard to obtain on a Sunday when your sisters bloke need the car for his work on monday morning! (Voice of experience!)
Nov 15, 2008 21:26:31 GMT
also if you wedge a screwdriver into the M6 bolts that holds the plastic water pump pulley to lever the viscous nut off, its a safe bet that they'll bend and crack the pulley. long chisel works well though
Nov 15, 2008 23:57:12 GMT
Hey B&D, that reminds me, I've done that too!
Bet they still talk about me at BMW! Ha ha!
fordghiarsxrboy
It is a 32mm! And it is a left hand thread! And if your car has a plastic thermostat housing try not to smash it up with the spanner when undoing the fan as they are hard to obtain on a Sunday when your sisters bloke need the car for his work on monday morning! (Voice of experience!) yep did that too and broke the plastic water pump pulley.got all my bits from euro car parts.stevenage. very reasonable price too.
stuey
ram thruster 4000
Nov 16, 2008 15:11:47 GMT
thanks for all your advice guys heres a pic of thanks-
stuey
ram thruster 4000
Nov 19, 2008 14:38:56 GMT
done in 45mins!!! many thanks to all who helped, epscially B&D with the step by step guide he sent me..(it also gave me the mojo to fix the fiat after its trip home on a low loader the other night!) goes to show RR is a great community when you need help.. another pic in thanks!
