need to raise funds to pay for the 2.0 8v conversion, so my old engine has to go.
On the last trip to Spamspeed it made 94BHP (at the fly) and is a screamer.
1275 MG Metro Bottom end and cam (good oil pressure, over 40 lb/ft at tickover when warm and 70 at higher rpm) with stock gearbox with 3.7 diff, It had new drop gear bearings fitted when put together. - £sold
Monster valve head, not sure of the exact spec, think it is 37mm inlets and 31 or 32mm exhaust, they are as big as you can get without off setting the valves - Provisionaly sold
1.5:1 roller tip rockers - Provisionaly sold
Weber 45 on 5" steel maniflow inlet with decent type linkage, twin cable type (weber was rebuilt before fitting last year) - £250
Steel rocker cover with Miglia style breathers - £25
Billet ultra light flywheel with lightened steel back plate and AP orange clutch- £sold
starter motor - £10
MG elecy dizzy with new module, cap and rotor (but needs 1 tread repairing) £25
1275 top rad hose and rad bracket (what you need when fitting a 1275 in a 998) - £5
Coleection from just outside Bristol, will be available in a few weeks.
starter motor - £10
