stuey
ram thruster 4000
Sept 28, 2008 15:26:58 GMT
Ive recently aquired an electric fuel pump for my 126 but I'm trying to think of the right way to wire it in... should I take a feed from the ignition or fit a seperate switch and a small seperate fuse holder... any input would be welcomed heres a shiny pic of a supercharger in thanks-
1987 fiat 126-nearly actually done! 1972 beetle - lawn art 2003 z4 daily-new wheels a comin! 2008 R56 Mini cooper "mental Mickey"
Seth
Sept 28, 2008 15:35:35 GMT
Either or both! When I put an eectric pump on the SAAB I wired it from the ignition and added a seperate hidden switch as a basic antitheft device. You can laso get inertia switches so the pump is cut off if you hit something hard. Thats a nice blower installation! Looks like a B-V8?
stuey
ram thruster 4000
Sept 28, 2008 15:54:33 GMT
many thanks I will head to the driveway tonight with soldering Iron in hand and yes it is.. shamelessly stolen from the interweb but lovely none of the same! a judson for your time-
Sept 28, 2008 16:00:34 GMT
Also consider wiring it through the oil pressure warning switch using a suitable relay. That way if the engine cuts out due to failure or a crash, the fuel pump shuts off itself. Make sure its wired up so that the pump primes when the ignition goes on, but cuts out if the oil switch closes, otherwise there will be no fuel as you crank the engine to start it.
Sept 28, 2008 16:23:29 GMT
You running carbs or efi?
