Picked these two backboxes up from work a while back, I was going to probably use one of them. Not sure what car either of them are for, but neither look hard to adapt to fit anything.
First up we have a "Peco Boxer" back box, I have a slight suspicion it's for a Corsa, but I'm more than likely wrong.
The outside of the tailpipe measures 11x9cm, and the hole in the center is 5cm.
The inlet pipe is split to allow it to clamp over plain pipe, and measures just over 2" ID.
I've also got a Mongoose box, its got twin 7cmx9cm tailpipes, each with a 4.5cm central hole. The inlet pipe is 50.8mm OD, 47.9mm ID, and is not sleeved.
Both of the back boxes are unused, ex shop display so they have minor marks but no dents. I've had brand new exhausts come a lot worse!. Neither look to have much in the way of silencing, so expect them both to be fairly loud, but nice and free-flowing..
I'm asking £30 each, Ideally collected from Rotherham, but I will post for £15 each which is the cost of a courier.
