Query for all those Goof owners out there. I have been welding a Mk2 Gti up for someone (usual trick, water behind the mong underneath and the rust had a field day....) and I hopefully have done, but, there is a rusted out drain hole I am unsure about.
It is the panel right at the rear on the passenger side that you access the bumper mounting bolts through and it has the slinging eye attached to it. Is this structural? Or can I just trim the hole bigger and leave it at that?
