carmad
ok i am on the hunt for a set of wheels for my marina
but i know nothing about the offset and pcd and center hole
does any one know this info
now for the wheels
i need to know the same for a ford escort mk1 ?
basically trying to get ford wheels on my marina and need to know what size of spacers/adaptors to get made up
thanks
Marina = 3.75 inches, Escort (MK 2, at least) = 108mm
Last Edit: Aug 8, 2008 19:34:58 GMT by bigginger
Davenger
It's only metal
Club RR Member Number: 140
MK1 escort is 108 too
carmad
offsets?
usually 19mm - rs alloys, mex steels, capri laser's etc are anyway.
Marina shares it's stud pattern with Spitfires / Herald / Dolomite and the MGF. Oh and a large number of single-seat race cars. So there are wheel options out there without having to resort to redrilled hubs.
carmad
You can DEFFO get allycats in 33/4, I was outbid on some a couple of weeks ago. I have a feeling you can get them new if your pockets are deep enough.
carmad
don't really mind the adaptor bit
means i can get em sitting out an extra 1"
Marina shares it's stud pattern with Spitfires / Herald / Dolomite and the MGF. Oh and a large number of single-seat race cars. So there are wheel options out there without having to resort to redrilled hubs. MGFs too, I believe
Marina wheels are 3.75" 4-stud (3/8" UNF) with a 13mm offset. Dolly alloys and MGF/Maestro/Montego alloys/steels have a 35mm offset so a set of Grayston spacers would give you a -10mm offset (35-13=22mm, Graystons are 32mm thick, hence -10mm). I have 15" Montego alloys on my Ital estate with spacers and as long as the bushes and shocks at the front are OK they are no aggro. TR7 alloys bolt straight on, as do Spitfire/GT6. 98mm PCD will go on with wobble bolts (Marinas are 95.25mm) or 'persuasion' Have a look here www.fastmarinamagazine.com/for more details. ;D
Rover Metro - The TARDIS - brake problems.....Stored Rover 75 - Barge MGZTT Cdti 160+ - Winter Hack and Audi botherer... MGF - The Golden Shot...Stored Project Minion........ Can you see the theme?
