I'm emigrating to New Zealand so it all has to go.
V6 Cosworth BOA running engine removed from a Capri converted to manual flywheel, gearbox, clutch, starter motor, modified loom and ECU with air flow meter and spark amplifier. I may be able to deliver for a small fee.
Rough Recaro front seats. No runners or adjusters. Would look great in a Rat Rod
Capri front springs
Capri front shocks
Front top caps
Capri front spring top cups
Capri front hubs
Capri single leaf springs
Capri 2.8 front crossmember and power rack
Mk1 Capri crossmember
Mk2 Cortina crossmember, TCA's and ARB
ST24 radiator only a few months old. I was going to use it with the engine. I also have the cowling and fan.
I want £300 for the engine, gearbox and loom. Make me an offer for the other bits. Parts are in Benfleet in Essex. I may be able to deliver to Essex,Kent,Suffolk. Cheers
Capri front springs
Capri front shocks
Front top caps
Capri front hubs
