1300 GT spec Ford crossflow engine and 4 speed box. Engine is taking up space in the garage, still turns over but probably needs a rebuild. 711 block with twin choke weber carb, needs sump pan as this one is now porous from being stood on concrete floor also requires rocker cover. Engine was removed from a Dutton and ran strong suggesting it may have a uprated cam in it, but I have no proof of this. The head is still bolted on so do not know if it has been modded.
Comes complete with flywheel,clutch and Dutton length prop (short 1 piece)
£150 ono
£150 ono
