stuey
ram thruster 4000
Last Edit: Jul 7, 2008 13:06:47 GMT by stuey
1987 fiat 126-nearly actually done! 1972 beetle - lawn art 2003 z4 daily-new wheels a comin! 2008 R56 Mini cooper "mental Mickey"
Go for it.
My dad also had one of these years ago when he was a school teacher. Said it used to really go.
roj
Kinda New
Made in the days when car bodies were made of thick enough steel to withstand the rust worm for quite a while...
Good luck with that.
Loxlee
Ford Capri with 1600cc's of pure power!........
looking forward to this one what sort of plans do you have for it?
stuey
ram thruster 4000
I'd like... seriously low with banded steels, aquaplane tuning kit, possibly bagged otherwise stock oh and one dems sunvisors!!!
but id quite like some v6 ford mechanicals in there too...
Last Edit: Jul 7, 2008 21:17:13 GMT by stuey
Loxlee
low with a visor you cant go wrong really!
full landy running gear with the engine....4wd 100e? lol
spacekadett
F*cking take that Hans Brrix!!
but id quite like some v6 ford mechanicals in there too... T'was the original plan for mine, but it went missing before I could pick it up (long story : . At the time BnDs' works had broken a TVR with a Swaymar 3.1 in it. I figured it would be quite entertaining with that in it ;D Bruisercapri bought the lump before I managed to get my mits on the 'E tho. Pity I missed the times when you were trying to give it away, as that shell looks a helluva lot better than mine did when I started prodding it!
Mechanic's rule #1... If the car works, anything left on the floor after you finished wasn't needed in the first place
1959 100e angliaDeleted
@Deleted
Good luck with it. My 100E never rotted as much as the later cars and a lot more unbolted and wasn't structural so it shouldn't be too hard to fix
If you seriously want it blast cleaned I can recommend someone who is excellent and reasonable. Keep away from the V6 tho (if Capri) as its way too heavy and not that powerful. A modern Vectra V6 would be a good choice though. The engine bays are tiny on these things though, so you may be better off going for a modern 4 pot instead.
stuey
ram thruster 4000
If you seriously want it blast cleaned I can recommend someone who is excellent and reasonable. Keep away from the V6 tho (if Capri) as its way too heavy and not that powerful. A modern Vectra V6 would be a good choice though. The engine bays are tiny on these things though, so you may be better off going for a modern 4 pot instead. thanks for the advice in the engine-I have thought about the zetec route tbh... the blasting is going to be carried out at ripblast a local company who about 5 mins down the road from where the shell is currently parked...
Last Edit: Jul 9, 2008 16:31:32 GMT by stuey
executioner
"all my wuckin fords keep muckin fuddlin"
I'll be watching the progress on this one as ive just captured an 100E myself and will be starting a thread shortly (as soon as ive finished jobs in the house that is lol ) I'm still undecided what power to use ,i fancy the idea of 2.0 zetec on bike carbs but i will probably think about that at a later date ,its already had steering rack conversion and pinto lump with 5 speed and i want to see how i can keep costs to a minimum .....good luck!
Old fords never die they just get rustier.....and then I buy em !
stuey
ram thruster 4000
Aug 21, 2008 17:51:22 GMT
Today tidied my garage and then dragged the engine out and removed the half inch of dust of it and turned it over, Tommorow I'm going to organise getting the shell picked up for blasting and priming so I can start the project in earnest!! heres an engine-
@Deleted
Aug 22, 2008 10:36:49 GMT
Does that engine run and is it going back in the car?
stuey
ram thruster 4000
Aug 22, 2008 13:48:53 GMT
Does that engine run and is it going back in the car? It hasnt run in a good few years but certainly did when it came out, Its been dry stored and turned regularly and will be going back in (hopefully with a full complement of aquaplane tuning goodies...)
Aug 22, 2008 19:49:28 GMT
Does that engine run and is it going back in the car? It hasnt run in a good few years but certainly did when it came out, Its been dry stored and turned regularly and will be going back in (hopefully with a full complement of aquaplane tuning goodies...) whoop whoop ! you Tried to GIVE it away? blimey i would have had it straight away lol !! just noticed you only up the road from me 2 good luck with it, looking gurd ;D Wil.
" What cam you got in that mate?" " Bitta' box Section"
