May 23, 2005 21:57:06 GMT
How can you tell if a car has a Limited slip diff fitted?
I have been told that if you turn one of the wheels on a car with an LSD the opposite wheel goes in the same direction instead of the other way. Is this true?
BS Nymph Singer Chamois Coupe Series 3 Landy
racer86
'76 Toyota KP30 / '73 BMW 2002 / '93 Mini
May 23, 2005 23:05:41 GMT
i don't think so, it operates as an open diff until the forces acting are enough to engage the cluches ect, so just turning it by hand wont cause it to lock. or i might be talking poo.if they both turn the same way it might be welded . best way is do a big burn out ;D 1 means open diff 11 its a slipper!
racer86
i was talking poo then, sounded good though didnt it
Cheers anyway racer86 ;D
May 24, 2005 11:06:31 GMT
I saw the heading there and thought this was a discussion about something else, i.e. something that doesn't do much for your cornering but has other noticable effects! ;D ;D ;D ;D ;D ;D ;D ;D
"He's not the messiah, he's a very naughty boy!"
May 24, 2005 11:07:47 GMT
Yeah i thought the same when i started the thread ;D
May 24, 2005 11:08:29 GMT
;D ;D
May 24, 2005 15:36:15 GMT
Damn................with the title of this thread I thought there was going to be a discussion about Pink Elephants riding mopeds through a grassy field or in my case some years ago, crocodiles floating in my mates pond.
71 Alfa GT 1300 Junior 89 Alfa 75 3.0 V6 Veloce 89 Alfa 75 3.0 V6 America 2015 C220 estate Daily shunter
May 24, 2005 22:09:03 GMT
I never thought Limited slip diffs had that effect on people ;D
May 24, 2005 22:11:56 GMT
95% of LSD`s operate as you thought, ie turn one wheel and the other wheel turns the same way if the diff is open or I think a torsen the other wheel will turn in the opposite direction
I'm dressed in black again until someone invents a darker colour.
Cheers igbandy
