Jun 20, 2008 12:29:49 GMT
Just read that people use this to clean out engines too. Run the car for a week with pure vinegar instead of water, then flush, repeat in feeded, gets all teh rust and curse word out of old engines water passages. Sounds like a good idea as i have 2 50 year old iron block motors
Tim
Jun 20, 2008 12:33:21 GMT
Is it safe to mix battery chargers and water like in those pics?!?! the chargers/leads should never have to contact the water just don't touch the water or the metal whilst its on!
Jun 21, 2008 23:07:54 GMT
The charger is fused, just keep it switched off until it's all set up.
Jun 21, 2008 23:26:03 GMT
I can see the potential, hook up to the mains, connect up to an outdoor pool and clean up complete bodyshells with no effort at all...
and on the serious side, any old battery charger do?
"Chasin' the gash, with a four-out-the-dash"
Jun 21, 2008 23:40:09 GMT
Anyone know how long the vinegar stays useable for? Well I wouldn't put it on your chips afterwards... I've used the brick cleaner stuff before, theres a tub in the garage somewhere, not used with electrolosis but it did a fine job (can't remember what I used it on though) Besides, any container with that many warning signs on it must be good
I can see the potential, hook up to the mains, connect up to an outdoor pool and clean up complete bodyshells with no effort at all... and on the serious side, any old battery charger do? The more power the better. I was thinking about getting another charger the same size and run them both at the same time.
mercmad
ye, I have done the voinegar thing. I tested it in a plastic jar and a few rusty nuts n bolts and bits of steel. I left them maybe 48 hours and once removed a given a ligh rub over, the rust came away very easilly. Seems to take a fair bit of time on heier rust though - but then, I'm using cheapy supermarket vinegar, maybe thats why? As above, I will be trying the electrolosys method next, Looks like it could be significantly better. your French Wine does the same thing.... ;D ;D ;D Seroiusly though,for removing white oxide from alloy bits,vinegar is king. And if you dump a liter into the radiator it will clear out all the gunk after you let it run for a day or so. Flush it clean afterwards.
mercmad
I can see the potential, hook up to the mains, connect up to an outdoor pool and clean up complete bodyshells with no effort at all... and on the serious side, any old battery charger do? make sure theres no one in the pool or else you will get actual Bodies floating in there. ;D
Had very little result with the vinegar method. It could be because i used malt - assume people are using the clear stuff? Garage smells horrible now!
Mr K
interesting stuff! will have to try this! Had very little result with the vinegar method. It could be because I used malt - assume people are using the clear stuff? Garage smells horrible now! i think balsamic is the way forward....
'Twas me that tried the Tesco Value vinegar and I found it to be 101% useless on a set of Pinto exhaust manifold studs/nuts and cam cover bolts & washers. Even with four weeks of soaking! Might work better on mild steel though. assume people are using the clear stuff? Maybe.... Anyone?
My fleet: Suzuki GSX-R600Y SRAD with bald, melted tyres A borrowed Mondeo
mrs brought me some white vinegar but it still says malt on it. will check tonight if any difference but i reckon this method is curse word so far.
I used the 17p a bottle malt stuff on my rear beam mounts for the rocco. I left it to soak for over a week and it got the majority of the huge chunks of rust off, but to get a shiny finish I imagine the more expensive clear distilled vinegar or electrolysis is better.
yeah, your supposed to use clear vinegar of 5% aceitis? acid or more.
Can completely disolve metal if your not carefull!
Cool, will track some down.
Thought I'd have a go at this electrolysis method to clean up my manifolds before I painted them. For the cost of soda crystals (79p) and a plastic planter (£1.99) I'd have little to lose. Here's the planter with my two steel anodes fitted. I used 2 anodes as the process works best in line-of-sight, so I'd attack it from both sides. This is my battery charger. Bit of a problem this as it's 'intelligent' and knows it ain't a battery connected to it, so keeps throwing up fault codes. After a bit of tinkering I got it to work and was pulling over 10amps. Gets fairly lively in there with 10amps! Another problem with my charger is it expects to see the current reduce when it's charging a battery, but this is a constant load so it throws a fit and turns off after a few minutes - and has to be reset, so I couldn't leave it overnight which is probably what is needed. Here's some results from just 1 hours treatment. Before: After: It's not obvious from the photos, but it's quite impressive for an hours work. All the rust that was impossible to get to between the 4 pipes has gone! I need to get a 'dumb' battery charger and do some longer runs. So if you're confident about using electricity around water etc. I'd say have a go, it's cheap and effective.
Last Edit: Jul 6, 2008 13:58:24 GMT by celicaV8
I can see the potential, hook up to the mains, connect up to an outdoor pool and clean up complete bodyshells with no effort at all... and on the serious side, any old battery charger do? get an old 100amp+ arc welder, few sheets of metal, and an old container unit and thats not as silly as it sounds. you could have a car dipping factory for under £500 ;D anyone with a link to the electrolysis process?
rob0r
East of England
Club RR Member Number: 104
Vinegar rust removalrob0r
@rob0r
Club Retro Rides Member 104
I'm keen to try this, I have some BMW E21 rear trailing arms and subframe that I was going to attack with a grinder and wire wheel attachment. Any idea with a standard battery charger how long it would take to do one trailing arm?
E30 320i 3.5 - E23 730 - E3 3.0si - E21 316 M42 - E32 750i ETC
I'm assuming what the power supply is isnt important, just 12v for safety and putting out as much ampage as possible?
Jul 11, 2008 15:21:02 GMT
Most interesting thread eva!!!
