GJM
Alloy engines; like communism- great in theory.
May 30, 2008 18:23:21 GMT
Ahoy-hoy all. My tastebuds are a ticklin for a new motor! Sold the Imp a few weekends ago, 4 years of drooling over modified Imps having taken its toll, thus I'm looking for a nice project Imp to get my teeth stuck into that I can call my own! However, also feeling like a bit of a change in the daily driver catagory. Driving about in a 98' Fiesta LX 4 door every day is well....boring as watching paint dry really. So, something retro, cool, practical, hopefully reliable as a daily driver is called for. Been tossing ideas around for a few weeks but couldnt really decide on anything solid, however after searching ebay the other say the MGB GT sprang to mind, they seem to get used as daily drivers more than most classics out there, many being extensively modified for the job. They seem really quite cheap at the moment for what ever reason, great spares availablity, cool in every way and totaly practical. However, having never really looked properly at one, I cant say any of this for sure So, what they like? A late one make a good daily driver? Would have just under £2000 to throw at one. Any big niggles or mechanical problems with em' I should look out for? Let the learning curv begin Random fleabay examples: cgi.ebay.co.uk/1973-MG-B-GT-BGT-25000-MILES-NEW-MOT-LOTS-HISTORY_W0QQitemZ170221263670cgi.ebay.co.uk/MGB-GT-1970-RED_W0QQitemZ190223410712QQihZ009cgi.ebay.co.uk/STUNNING-1981-MG-B-GT-PARTIALLY-RESTORED_W0QQitemZ220234859994cgi.ebay.co.uk/1979-mgb-gt-in-lovely-condition-in-red_W0QQitemZ220240090029
Last Edit: May 30, 2008 18:39:06 GMT by GJM
lae
May 30, 2008 19:02:57 GMT
I very nearly bought one of these, went for a Midget instead
Pros B-Series engine sounds amazing Looks nice Waterproof Fun to drive, you feel very 'involved' and it makes nice mechanical noises Very easy to find spares Very easy to modify for power, handling, reliability, economy Other MG owners give you a wave when you pass them Pretty comfortable and not bad on the motorway either
Cons Rust - check sills, floor, around headlamp bowls, suspension A tad slow, weight of the GT roof, but modifications are cheap and easy Can still only fit two people in there, three at an absolute most, and not much carrying capability (more than the roadster though!) A bit common (that's why values are falling a bit) Values are falling a bit! But if you take car of it, you'll get back what you pay for it Not great MPG, around 30 if you're sensible, but modifications can improve this somewhat Unreliable - but modifications can definitely improve this A bit of an old man's car... but modifications can improve this!
Currently: Mk1 Focus blandmobile
Formerly: 1969 MG Midget 1972 Avenger GT 1981 Datsun Cherry 1989 Corolla 1979 Mercedes W123 200D 1995 Ford Falcon 1996 Ford Telstar (bet you had to google that one)
May 30, 2008 19:09:17 GMT
GJM
May 30, 2008 19:11:24 GMT
The new 'flat cap on crack' look ;D
Nathan
Club RR Member Number: 1
Tell me about MGB GTsNathan
@bgtmidget7476
Club Retro Rides Member 1
May 30, 2008 21:30:36 GMT
Freakin love mine.
Like any old motor a well looked after one will serve you well. See past the old man curse word and its a excellent motor. Mods to the engine are very expensive so go down the transplant route, MX5 box and tranny slide straight in with only mount modification (even the shifter pops up in the right place).
Check in front of the rear tyres rot here defo means the sill has gone, this part of the sill goes under the rear wing, which is not a bolt on item. Get one with good front wings as repo parts are expensive and require felting for fitment.
The Motor is bullet proof, so is the tranny if test drving one make sure you test the Overdrive. I tend to see a few on ebay going cheap due to slipping clutches, in 90% of cases its actually not the clutch. There is a small flat filter on the bottom of the overdrive, if this is dirty (most were never replaced) you get the feeling of a shagged clutch.
Rubber bumper models tend to be slower due to the weight of the bumpers, they also ride higher but this can be solved for under £100. late 74's onward are the simplest to fit the RV8 due to the front cross member changes. General running parts are easy toget hold of, in fact my local autofactors has nearly everything for them.
I get the biggest smile from mine every time I drive it.
GJM
May 30, 2008 22:02:49 GMT
Cheers for the lowdown
Must say, I do like them as well.
Used to know a GP when I was a youngster and she had one..... drove the crapp out of it. (She was a local hero)
For: beards Against: Minilite replicas
*n
PhoenixCapri
West Midlands
Club RR Member Number: 91
Tell me about MGB GTsPhoenixCapri
@phoenixescort
Club Retro Rides Member 91
Wow those pics are a lot of reasons to want a B! For: look cool as hell with a little work Against: slow as standard!
WOW!!Some serious machines there!!
Just don't get a rubber bumper one,never like them TBH.Just my 2p
May 31, 2008 11:08:53 GMT
Early rubber-bumper B's (74-76) had no anti-roll bar and handled like a greased pig on ice. Later ones (post-'76) were much better.
Avoid 'handling kits' like the plague, my dad's '76 Roadster has them and it destroys the ride. His also has a full stainless LCB/single-box system that sounds awesome.
My choice would be a '69-'73 GT with the single hoop grille and BLMC badges, on Rostyles....the ones the flat-cappers like least.
simes
May 31, 2008 12:49:32 GMT
Get an MGC GT and be different!
Simes
205Mi16 - 262 cams, Jenvey Throttle Bodies, Emerald managment blah blah...... E91 320D MSport Honda NC30 Vespa 300GTS
May 31, 2008 14:49:18 GMT
captainwow wrote: "Just don't get a rubber bumper one" But converting from rubber to chrome bumpers is do-able. In fact, the blue GT shown above is a 1979 rubber-bumper model. Big weight reduction. Some welding required. briandamaged wrote: "Early rubber-bumper B's (74-76) had no anti-roll bar..." True, but it only takes an hour to fix that and with any luck a previous owner will already have taken care of it for you. simes wrote: "Get an MGC GT and be different!" Now you're talking! An MGC-GT can be tremendously improved with V8 power, and doing so creates a car that's very " different". The MGC engine was horribly overweight (as was the B-series four-banger.) A Ford 302 with stock iron block and aftermarket alloy heads weighs about 460lbs, versus 650lbs for the original MGC engine. The MGC crossmember suits the Ford oil pan perfectly! (Incidentally, big Toyota brake calipers bolt right on to an MGC as shown below.) You have to wonder why MG didn't work with Ford to put their V8 in the MGC to begin with. Ford had already been providing the engine to Sunbeam for the Tiger (so the idea should have been obvious), and Chrysler had recently bought Sunbeam (and the rest of Rootes Group,) so the Tiger was obviously destined to disappear and leave Ford without any conflict-of-interest. Of course if you like the MGC look, you could simply fit an MGC bonnet onto an MGB. The bonnets are still available new, or you can get a fibreglass one. Anyway, check out this authentic 1969 MGC GT with Ford V8: www.britishv8.org/MG/BobElwin.htm
topcat
May 31, 2008 15:05:53 GMT
Because they were the competition, as were Rootes, besides they had their own v8 which they did fit. Agreed the Ford motor would have been better. Unfortunately evolution and parts sharing (usually lack of) in BMC and BL makes little if no sense.
May 31, 2008 16:23:08 GMT
You've got the timing all wrong. MG didn't have access to the Rover V8 when they were developing the MGC. Rover hadn't even licensed the design from GM yet. Besides that, Rover was still independent. Shortly after Rover licensed the aluminum V8, Rover was acquired by Leyland. The big BMC / Leyland merger happened still later. Thus, the MGB GT V8 (with Rover V8) wasn't released until October 1973... which was quite a long time too late.
If anything, the Rover / GM deal supports my argument. It's another example of successful British/American cooperation.
MG engineers did build a prototype with a Daimler V8 in the mid 60's, so obviously they were thinking about engines from outside of the BMC umbrella.
The Triumph (Stag) V8 hadn't been developed yet... besides, (a) it was a horrible engine and (b) there was no chance Triumph would have permitted its use in an MG.
The question boils down to "how much autonomy did MG have within BMC?" because clearly MG and Ford had almost no overlap in their customer-base at all. (Sure, this wouldn't have been true with BMC's other divisions in the UK market.) But in the late 60's, the Ford V8 would have tremendously helped MG sell cars in the North American market... and that was actually a bigger market for MG than all of UK and Europe combined.
Ford's perspective? Selling engines to Rootes (and to Shelby for the Cobra) was cool with Ford, even for sports cars sold in the North American market. They had nothing to lose, and they had some engine/parts business and good publicity to gain. Ford's real competition was GM and Chrysler.
Nathan
@bgtmidget7476
May 31, 2008 21:10:41 GMT
Excellent website and some Proper GT's.
My advice, get one and you I bet you love it.
GJM
May 31, 2008 22:11:37 GMT
Seen some great ones at Tatton Park classic show today Still not sure what I want as yet, but deffo at the top of my list so far, problem will just be finding a half decent one suitable for daily driving for less than £2000
Last Edit: May 31, 2008 22:11:55 GMT by GJM
