Shortcut
I won't be there when you cross the road, so always use the Green Cross Code.
With the new warm air I've had the drivers window on the goof down for the first time in months and noticed that the turbo has started making this tish noise on changing up. It used to make a little chirp from time to time but its doing it all the time now.
any ideas? Sorry it's not retro but it's me daily.
This space available to rent. Reach literally dozens of people. Cheap rates!
vroom - tishBenzBoy
@benzboy
Club Retro Rides Member 7
Weak BOV spring? Have you noticed any drop in performance?
Shortcut
Weak BOV spring? Have you noticed any drop in performance? Yes. i thought there was a slight lack of oomph. Nothing major, not like a turbo pipe splitting or anything just a bit of sluggishness.
LowStandards
Sounds like a possible boost leak! I hope to god you aint got a Chav Valve... Especially on an ECU controlled car
Shortcut
Sounds like a possible boost leak! I hope to god you aint got a Chav Valve... Especially on an ECU controlled car certainly NOT! Although I'm concerned that it's starting to sound like I do!!
LowStandards
Its either fine and you've just not noticed it, oe recirc' valves do tish a little or its a leak somewhere, though you'd normally noticed a spike in boost. I'm gonna guess everythings ok...
61stu
Coincedence my non retro 54 Diesel Fiesta has just started making a similar noise
