Hey all - some of you may have seen my ride out and about gas hopping or showing off around good ol' Weston He's an 84' Regal - imported by someone from Bristol last year - the poor bloke was ripped off IMHO. Most American lowriders are of questionable quality...and this one is no exception Shocking work on the whole install - bad welding, curse word wiring, curse word fabrication - the list goes on. So i'm currently working my magic on it slowly this winter. In the middle of a total frame wrap ATM - this'll give me the rigidity for higher hopping and pulling stable static 3's.
Last Edit: Dec 3, 2007 8:50:49 GMT by rmad
Bouncy Bouncy ;D
Okay - here he is as he arrived on my driveway after i bought him from the poor sod in Bristol...... Story is it caught fire in the container on the way over, as the switchbox was left active, and the pumps ran until the batteries got so low, they just burnt up.... And set fire to the inside trunk.... no huge damage, but hoses and wiring were totally shot to hell. I started ripping it all out and began crawling over the cock-ups. Here are the highlights... Fuse keeps blowing? Just fit a bigger one... if it melts the holder....just add a bigger one....... Earthing - wassat then ? They took the regal out using a forklift....and crushed the tank..and the pickup..... "Amazing" ICE install.....
Bouncy Bouncy ;D
Onto the actual hydraulics then..... I won't go into the tech side - i can't be arsed.... ;D Basically, this is where the hydraulic ram was "fitted" to the rear axle.... and this is the "hymes joint"...not. A chain bridge is sometimes fitted to help as a lever to pull awesome 3 wheels... this was the owners attempt....a piece of angle bodged to the cross brace frame section.......it didin't work.... upper arm bushes were absent...... Front cylinders were floating about in the spring cups.... missing hub nuts.... Astro shelf hinges.... the list went on and on and on..... ;D
Bouncy Bouncy ;D
Ether
Jeesus, that's a whole lota bodgework. Great purchase, though! Are you keeping those murals or respraying..? Good luck with it, dude
I gave the rear cylinder mounts a good tw** with "old faithful" and they just flew off Fitted PROPER cylinder mounts..... Started on correct axle bracing and support.. reworked a bodged setup in the boot that worked...and was SAFE ! finished supports, lowered the upper arms by 5" I spent 3 days gilding the areas of the bodywork that were damaged....
Bouncy Bouncy ;D
Jeesus, that's a whole lota bodgework. Great purchase, though! Are you keeping those murals or respraying..? Good luck with it, dude Murals are staying dude - i was gonna respray, but relented after a while cos they polished up really well
Bouncy Bouncy ;D
Neil
Nice whip! How did you get it MOT'd?
Nice whip! How did you get it MOT'd? unbeliveably - it already had one... hooky i'm bloody sure of it
Bouncy Bouncy ;D
street
6.2 ft/lbs of talk
Wow, that would scare off most seasoned pros! Seriously shocking bodgery! You've done great work sorting it out so far, really getting sorted out by the looks of it. Nice paint and murals too, love it
Ray
1964 Anglia 105e - MK4 Polo Sinbad
Wicked car!! Glad the murals are staying!
Nice 1 G I'll be round for a coffee this week & check out your progress.
berendd
omg that's serious bodgework, good job to leave the murals on, they're from the category so wrong thery're right again....
nice piece of machinery, and have fun welding!
Colonelk
Club RR Member Number: 83
1984 Buick Regal.....Colonelk
@colonelk
Club Retro Rides Member 83
Thats some crazy bodging! I know I'm no master craftsmen but seriously!?!
Dez
Club RR Member Number: 34
1984 Buick Regal.....Dez
@dez
Club Retro Rides Member 34
those bottom cylinder mounts look to be just what i need for mine- where abouts did you get them/how much were they?
Respect for saving this lowrider from lowrider death. It really was bodged in every way possible - i would have walked away and scratched my head! The frame wrap looks good - full marks for doing it all yourself as well....
